Kossel custom build problems with Z axis February 07, 2018 04:45AM |
Re: Kossel custom build problems with Z axis February 07, 2018 05:43AM |
Re: Kossel custom build problems with Z axis February 07, 2018 09:40AM |
Re: Kossel custom build problems with Z axis February 07, 2018 10:15AM |
Re: Kossel custom build problems with Z axis February 07, 2018 03:43PM |
Re: Kossel custom build problems with Z axis February 07, 2018 11:57PM |
Re: Kossel custom build problems with Z axis February 08, 2018 12:00AM |
Archiclem
I had this issue, and it was one of the magball that was not properly fastened (the effector was loose). you need to check every bolt... And what is the length of your bowden tube ? may be it's too long ?
Re: Kossel custom build problems with Z axis February 08, 2018 08:33AM |
Re: Kossel custom build problems with Z axis February 09, 2018 02:45AM |
Re: Kossel custom build problems with Z axis February 09, 2018 04:50AM |
ayudtee
A similar problem occurred before that was finally traced to the drive belts.
Skewed prints
HTH
Re: Kossel custom build problems with Z axis February 09, 2018 04:52AM |
o_lampe
Haydn apologized about the quality of his ball studs. They seem to be uneven. IDK exactly what he meant with that, but maybe it's worth the time to measure and eyeball them closely.
A ball that isn't round is the same as a rod changing length, depending on the mag-sleeves position. That would cause effector tilt in a reciprocating pattern.
Re: Kossel custom build problems with Z axis February 09, 2018 09:59AM |
Re: Kossel custom build problems with Z axis February 10, 2018 03:04AM |
Origamib
Is this all Haydn ball studs, or only older ones? I was not aware of such an issue
Re: Kossel custom build problems with Z axis February 10, 2018 03:34AM |
Re: Kossel custom build problems with Z axis February 10, 2018 07:52AM |
Re: Kossel custom build problems with Z axis February 10, 2018 07:53AM |
Re: Kossel custom build problems with Z axis February 10, 2018 08:27AM |
Re: Kossel custom build problems with Z axis February 10, 2018 12:06PM |
