Carbon rods: 6mm solid or hollow 10mm dia? February 21, 2018 04:02AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 21, 2018 07:42AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 21, 2018 07:57AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 21, 2018 08:16AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 21, 2018 01:36PM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 03:42AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 04:32AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 05:11AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 05:52AM |
hercek
The maximum moment of the stepper motor is also quite a limit when trying to achieve low dynamic error (low ringing). E.g. using a Nema23 stepper (103 Ncm) would lead to maximum acceleration of 12.8m m/s² while still having the errors in the range of 14 µm.
If you have ringing and do not drive your steppers with the maximum current the steppers and the stepper drivers allow then increase the driving current. It may help if some other errors are not much larger.
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 06:23AM |
dc42
0.9deg motors are better than 1.8deg motors here, because for the same holding torque they are twice as stiff as 1.8deg motors. In practice 0.9deg motors usually have a little less holding torque than similar 1.8deg motors, so the gain isn't quite double.
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 08:26AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 08:30AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 08:46AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 01:43PM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 06:19PM |
hercek
Micro-stepping decreases the holding torque very badly...
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 11:31PM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 22, 2018 11:43PM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 23, 2018 02:40AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 23, 2018 04:30AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 23, 2018 07:09AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 23, 2018 07:24AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 24, 2018 04:15AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 24, 2018 04:39AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 24, 2018 12:51PM |
If your Ø 6 mm diagonal (carbon) rods do not have any noticeable play at the joints and the joints move easily then your diagonal rods are not a problem.Quote
DjDemonD
I have linear rails on the XL, gates belts 6mm 2gt, Haydn rods 360mm 6mm diameter, smart effector and carriages. Its a 2040 frame with robot digg corners. So it has to be the belts, or the carbon rods.
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 24, 2018 01:04PM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 25, 2018 09:04AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 25, 2018 09:10AM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 27, 2018 02:03PM |
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 27, 2018 02:17PM |
DjDemonD
But I do need to make some new rods for the fishtank printer in abs or petg as it gets quite hot inside, if I can sort the leadscrews out first. So I could try the 10mm carbon tubes (assuming they fit over the Haydn rod ends?) and then I could swap rods and do some fairly well controlled testing.
Re: Carbon rods: 6mm solid or hollow 10mm dia? February 27, 2018 02:23PM |
