Need help setting up Delta Smart Effector in RRF. February 28, 2018 05:51AM |
Re: Need help setting up Delta Smart Effector in RRF. February 28, 2018 06:02AM |
Re: Need help setting up Delta Smart Effector in RRF. February 28, 2018 09:25PM |
Re: Need help setting up Delta Smart Effector in RRF. March 01, 2018 03:37AM |
Re: Need help setting up Delta Smart Effector in RRF. March 01, 2018 07:04AM |
Re: Need help setting up Delta Smart Effector in RRF. March 01, 2018 11:31AM |
Re: Need help setting up Delta Smart Effector in RRF. March 01, 2018 12:20PM |
Re: Need help setting up Delta Smart Effector in RRF. March 01, 2018 03:51PM |
Re: Need help setting up Delta Smart Effector in RRF. March 01, 2018 05:22PM |
; Configuration file for Duet 0.8.5 (firmware version 1.17 to 1.19) ; executed by the firmware on start-up ; ; ; General preferences M550 PCyberDelta Plus 2187 V3.0 ; Machine name M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like RepRapFirmare M575 P1 B57600 S1 ; Comms parameters for PanelDue ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration. M665 R116 L288.12 B116 H225.9 X0 Y0; Set delta radius, diagonal rod length, printable radius and homed height, as well as XY tower corrections M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them M208 Z0 S1 ; Set minimum Z ; Endstops/Probing G31 P100 X0 Y0 Z-0.1 ; Set Z-Probe Height and offsets. M574 X2 Y2 Z2 E0 S1 ; All endstops at high end, Active high M558 P5 R0.4 I1 H3 F1000 T1000 ;P = Z-Probe Type, 0 for none. I = inversion XYZ = use probe for homing axis. F = Feed Rate/Probing Speed. T = Travel Speed. M557 R116 S20 ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M92 X80 Y80 Z80 E80 ; Set steps per mm M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min) M201 X1500 Y1500 Z1500 E1000 ; Set accelerations (mm/s^2) ;M906 X800 Y800 Z800 E800 I60 ; Set motor currents (mA) and motor idle factor in per cent, It probably isn't supported in RADDS. M84 S30 ; Set idle timeout ; Heaters M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S100 ; Set temperature limit for heater 0 to 100C M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S300 ; Set temperature limit for heater 1 to 300C M570 H1 P30 T10 S120 ; Give more time to heat up M302 P1 ; Allows for Cold Extrusion ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ;M563 S1 ; Allows for tool nomenclature compatibility between Slic3r and RepRap (Tools 0&1 vs Tools 1&2) ; Network M552 S0 ; Disable network ; Fans ;Old M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off ;This is old M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P0 S255 T60 H1 ; Hotend cooling fan: Enable to auto kick on at 60c (make it 'thermostatic'). M106 P1 H-1 ; Filament cooling fan: Must do H-1, or it'll turn on with P0 for some reason. M106 P1 S0 ; Filament cooling fan: Must do, or it will go full blast on start ; Custom settings are not configured M501 T0
; bed.g file for RepRapFirmware, generated by Escher3D calculator ; 16 points, 7 factors, probing radius: 116, probe offset (0, 0) G28 G30 P0 X0.00 Y116.00 Z-99999 H0 G30 P1 X58.00 Y100.46 Z-99999 H0 G30 P2 X100.46 Y58.00 Z-99999 H0 G30 P3 X116.00 Y0.00 Z-99999 H0 G30 P4 X100.46 Y-58.00 Z-99999 H0 G30 P5 X58.00 Y-100.46 Z-99999 H0 G30 P6 X0.00 Y-116.00 Z-99999 H0 G30 P7 X-58.00 Y-100.46 Z-99999 H0 G30 P8 X-100.46 Y-58.00 Z-99999 H0 G30 P9 X-116.00 Y-0.00 Z-99999 H0 G30 P10 X-100.46 Y58.00 Z-99999 H0 G30 P11 X-58.00 Y100.46 Z-99999 H0 G30 P12 X0.00 Y58.00 Z-99999 H0 G30 P13 X50.23 Y-29.00 Z-99999 H0 G30 P14 X-50.23 Y-29.00 Z-99999 H0 G30 P15 X0 Y0 Z-99999 S7
Re: Need help setting up Delta Smart Effector in RRF. July 15, 2018 07:32PM |
Re: Need help setting up Delta Smart Effector in RRF. July 16, 2018 02:01AM |
Re: Need help setting up Delta Smart Effector in RRF. July 16, 2018 02:48AM |
