Marlin vs. Repetier on a delta printer March 24, 2018 03:03PM |
Re: Marlin vs. Repetier on a delta printer March 24, 2018 03:37PM |
Re: Marlin vs. Repetier on a delta printer March 25, 2018 04:51AM |
Re: Marlin vs. Repetier on a delta printer March 25, 2018 11:23AM |
Re: Marlin vs. Repetier on a delta printer March 25, 2018 01:28PM |
Re: Marlin vs. Repetier on a delta printer March 25, 2018 02:28PM |
Re: Marlin vs. Repetier on a delta printer March 25, 2018 04:32PM |
Re: Marlin vs. Repetier on a delta printer March 25, 2018 05:37PM |
Re: Marlin vs. Repetier on a delta printer March 26, 2018 05:21AM |
I have Repetier on the machine right now and do not want to mess with it since I am in the middle of a project. So I can not test this empirically right now.Quote
hercek
@ruevs:
Does the current Marlin firmware move the same speed regardless of the print head position?
You can check it by moving in one line (one g-command) from tower near to the tower base to the other side of the base. Does the print head have the same speed during the whole length of the move?
Re: Marlin vs. Repetier on a delta printer March 26, 2018 05:40AM |
The magnetic arms always disconnect with Marlin in this test - usually much sooner than in the test run I shot in the video. From this I come to the conclusion that for some reason Marlin causes much higher accelerations (maybe "micro" ones from buffer underflows or from driving the steppers "not smoothly" whatever that means).Quote
hercek
The Marlin firmware took longer time then Repetier to execute the same g-code. During Marlin execution the magnetic arms disconnected. I did not see the explanation why this happened in the video. But I did not look at the whole 45 minutes of it. It is just way too long.
One obvious explanation is that Marlin firmware experienced line buffer underflows. That stops movement momentarily which would have two consequences:
- the movement stop/resume happens with very high acceleration which disconnects magnetic arms
- momentary stops lead to longer print times
OR ... the marlin firmware executes everything a bit more slowly but correctly from the point of view of smooth movement (acceleration limits are obeyed) and the magnetic arms suck. What exactly happens was not clear from the piece of the video I looked at.
Why is 200 segments per second too high? I did not know how much the ATMega can handle with delta kinematics calculations, but I started with 200 (15 months ago) because that was the default in Repetier. I have used the printer all this time with 200 without any problems (the display is not a bitmapped one). So I configured Marlin the same.Quote
hercek
The whole test was not very interesting since it used segments per second set to 200. That is a too high value. The useful value is around 100.
Re: Marlin vs. Repetier on a delta printer March 26, 2018 06:32AM |
Re: Marlin vs. Repetier on a delta printer September 03, 2018 06:14PM |
