Callibration for independent tower tilts August 25, 2018 09:16AM |
Re: Callibration for independent tower tilts August 25, 2018 05:08PM |
Re: Callibration for independent tower tilts August 26, 2018 04:51AM |
[github.com]Quote
frankvdh
Can you share your method please? I have some errors in my printer that I suspect might be caused by tower tilt, but I'm not sure.
Because the maxima notebook shows bigger errors when the calibration does not compensate for the tilt. Also I know that the towers are not perfectly perpendicular (nor equidistant).Quote
frankvdh
How do you know that the measured error is due to tower tilt?
AFAIK, the current Repeteir does not support compensation for tilted towers. I use repetier with a small custom patch to print (itas,itbs,itcs) triple when Z-probing. Tower tilt support can be easily added but I did not do it yet. I'll probably do it ... maybe by the end of this year ... though I'm not sure I'll keep the stupid way how repetier defines tower positions. The polar coordinates are pain in ....Quote
frankvdh
And then how do you input the tilt into (e.g.) Repetier to correct it?
Genetic algorithm sounds like a time consuming way to solve this. Why using essentially a random search to optimize the fitness function when you can use gradient directed search. I used minpack library for that but only because it is built in maxima. There are better packages for this now.Quote
frankvdh
FWIW, I have a Java app which uses a genetic algorithm to minimise delta errors. So far it only uses tower angles, diagonal rod length, and endstop distances. However, I'm keen to add other variables. Especially if they can be fed back to the firmware to improve its positioning.
Re: Callibration for independent tower tilts November 11, 2018 04:20PM |
Re: Callibration for independent tower tilts December 05, 2018 09:22PM |
Re: Callibration for independent tower tilts December 06, 2018 03:25AM |
Re: Callibration for independent tower tilts December 30, 2018 03:44PM |
Re: Callibration for independent tower tilts February 02, 2019 01:58PM |
