Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 18, 2018 12:10PM |
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 18, 2018 02:14PM |
LMF5000
Is there a better way to get dimensionally accurate prints out of a delta printer?
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 18, 2018 06:30PM |
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 18, 2018 06:32PM |
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 18, 2018 06:45PM |
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 18, 2018 06:50PM |
You are out of luck with that budget.Quote
LMF5000
Max budget would be around $50
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 02:03AM |
hercek
From the technical point of view, a proper calibration does not need 32 bit electronics. One can do it with an 8-bit firmware controlled over USB. But nobody bothered.
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 02:17AM |
LMF5000
I think I may have been a bit unclear with my long description. Marlin's delta auto calibration finds tower angle offsets and delta radius (and some other corrections). However the delta diagonal rod length is something I enter in the config.h file and it stays fixed - it's not affected by calibration.
Can you suggest a suitable control board that will run the firmware you recommend? Max budget would be around $50 because I already spent quite a bit upgrading the drivers to TMC2208s.
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 06:18AM |
dc42
I'm sorry to be negative, but RepRapFirmware running on 32-bit electronics solved the problem of calibrating well-built delta printers three and a half years ago. It seems that other firmwares still haven't caught up;
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 06:23AM |
LMF5000
What I'm doing is printing the hexagon and measuring its sides. Then I plug those measurements into the spreadsheet ...
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 07:11AM |
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 12:25PM |
Re: Anycubic kossel poor XY accuracy even after 3 iterations of calibrating with hexagon. December 19, 2018 08:10PM |
