Just another 330x330x300 Ultimaker with direct drive dual extrusion August 03, 2017 07:22AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 04, 2017 02:07AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 04, 2017 07:57AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 04, 2017 09:26AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 04, 2017 09:38AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 04, 2017 04:47PM |
the_digital_dentist
I think you're overly constraining yourself by requiring closed loop belts (except for the small ones that the motor uses to drive the larger pulleys). Belts always need some means of tensioning and you're setting yourself up for trouble if you don't design it in from the start. The small belts need to be tensioned, too, and in your design the easiest way would be to use slots to mount the motors so they can be moved to tension the belts.
the_digital_dentist
Water jet cutters are not super precise. (see [wardjet.com]). The kerf is usually tapered- wider on the top of the cut piece and narrower on the bottom with the amount of taper depending upon the cutting speed. That means holes will be tapered, larger on the top and smaller on the bottom. If you're going to have the holes cut, I'd have them cut small and plan on opening them with a drill. I think it would be better to just drill the holes after the waterjet cutting is done because they can be accurately located that way, assuming you have access to tools to do so. You're relying on the accuracy of the hole positions to align the guide rails parallel to each other. What's your fallback plan if that doesn't work out?
the_digital_dentist
I would not have much confidence in using unguided ball screws. I suggest you select and design in the exact guide rails you're going to install if the unguided screws fail to deliver the required lateral stability. That way, if the ball screws don't perform adequately, you can simply bolt in the guide(s) with minimal disassembly of the machine. The next question is if the ball screws aren't perfectly straight, with 3 of them pushing/pulling laterally on the bed support, how big do the guide rails have to be to prevent Z wobble in the prints? The design of the coupling to the ball nuts can help if they allow for some lateral motion of the screw without translating that into lateral motion of the bed support. Have you considered a belt lifted Z axis?
the_digital_dentist
Putting electronics in the bottom of the machine is a great way to use some of the dead space, but if the Z axis isn't working and you need to get at the electronics, you have to get the bed up and out of the way by manually twisting one of the ball screws You might want to plan for that contingency and design a removable crank that can be fit over the end of one of the ball screws through the top of the printer. Otherwise, maybe a hinge that allows the bulk of the machine (including the Z axis) to tilt back while the base with the electronics remains flat on the table.
... If you made the machine taller, you could put the electronics in the bottom, separated from the build volume by an insulating panel.
the_digital_dentist
You're 90% of the way to having an enclosed printer that would allow printing ABS. All you need to add is panels to cover the holes... You might need more height at the top of the mechanism, too to feed filament.
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 05, 2017 03:01AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 05, 2017 10:47AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 18, 2017 09:50AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion August 24, 2017 11:29AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion September 03, 2017 02:36PM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion September 12, 2017 09:00AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion October 02, 2017 02:01PM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion October 05, 2017 09:23AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion October 11, 2017 07:03AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion October 13, 2017 10:01AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion October 23, 2017 02:09PM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion October 30, 2017 02:14PM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 07, 2018 04:20AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 07, 2018 04:26AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 08, 2018 02:49AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 08, 2018 03:59AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 09, 2018 07:09AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 09, 2018 10:20AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion February 10, 2018 11:19AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion May 03, 2018 07:35AM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion May 03, 2018 04:07PM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion May 03, 2018 09:44PM |
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion May 04, 2018 01:30PM |
Scooter68
Just got the BL touch probe working and finished setting all the offsets.
Re: Just another 330x330x300 Ultimaker with direct drive dual extrusion May 04, 2018 02:25PM |
