Marlin 2.1.2.1 Config: 2 Hotend loops, one Extruder, reasighn E1 to U pins February 03, 2024 12:38AM |
Re: Marlin 2.1.2.1 Config: 2 Hotend loops, one Extruder, reasighn E1 to U pins February 03, 2024 01:37AM |
Admin Registered: 13 years ago Posts: 7,013 |
diff --git a/Marlin/Configuration.h b/Marlin/Configuration.h index 20802a2839..2004334dab 100644 --- a/Marlin/Configuration.h +++ b/Marlin/Configuration.h @@ -88,6 +88,10 @@ // Choose the name from boards.h that matches your setup #ifndef MOTHERBOARD #define MOTHERBOARD BOARD_MKS_GEN_L + #define I_STOP_PIN 2 + #define X_STOP_PIN 3 + #define Y_STOP_PIN 14 + #define Z_STOP_PIN 18 #endif /** @@ -166,14 +170,14 @@ //#define Z2_DRIVER_TYPE A4988 //#define Z3_DRIVER_TYPE A4988 //#define Z4_DRIVER_TYPE A4988 -//#define I_DRIVER_TYPE A4988 +#define I_DRIVER_TYPE DRV8825 //#define J_DRIVER_TYPE A4988 //#define K_DRIVER_TYPE A4988 //#define U_DRIVER_TYPE A4988 //#define V_DRIVER_TYPE A4988 //#define W_DRIVER_TYPE A4988 #define E0_DRIVER_TYPE DRV8825 -#define E1_DRIVER_TYPE DRV8825 +//#define E1_DRIVER_TYPE DRV8825 //#define E2_DRIVER_TYPE A4988 //#define E3_DRIVER_TYPE A4988 //#define E4_DRIVER_TYPE A4988 @@ -199,7 +203,7 @@ * Regardless of these settings the axes are internally named I, J, K, U, V, W. */ #ifdef I_DRIVER_TYPE - #define AXIS4_NAME 'A' // :['A', 'B', 'C', 'U', 'V', 'W'] + #define AXIS4_NAME 'U' // :['A', 'B', 'C', 'U', 'V', 'W'] #define AXIS4_ROTATES #endif #ifdef J_DRIVER_TYPE @@ -227,7 +231,7 @@ // This defines the number of extruders // extruders **************************************************** // :[0, 1, 2, 3, 4, 5, 6, 7, 8] -#define EXTRUDERS 2 //************************************************** +#define EXTRUDERS 1 //************************************************** // Generally expected filament diameter (1.75, 2.85, 3.0, ...). Used for Volumetric, Filament Width Sensor, etc. #define DEFAULT_NOMINAL_FILAMENT_DIA 1.75 @@ -537,7 +541,7 @@ * */ #define TEMP_SENSOR_0 -3 -#define TEMP_SENSOR_1 1 +#define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 #define TEMP_SENSOR_4 0 @@ -1036,7 +1040,7 @@ #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG -//#define USE_IMIN_PLUG +#define USE_IMIN_PLUG //#define USE_JMIN_PLUG //#define USE_KMIN_PLUG //#define USE_UMIN_PLUG @@ -1169,14 +1173,14 @@ * Override with M92 * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] */ -#define DEFAULT_AXIS_STEPS_PER_UNIT { 400, 400, 400, 400 } // { 80, 80, 400, 500 } +#define DEFAULT_AXIS_STEPS_PER_UNIT { 400, 400, 400, 400, 400 } // { 80, 80, 400, 500 } /** * Default Max Feed Rate (linear=mm/s, rotational=°/s) * Override with M203 * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] */ -#define DEFAULT_MAX_FEEDRATE { 300, 300, 300, 300 } // { 300, 300, 5, 25 } +#define DEFAULT_MAX_FEEDRATE { 300, 300, 300, 300, 300 } // { 300, 300, 5, 25 } //#define LIMITED_MAX_FR_EDITING // Limit edit via M203 or LCD to DEFAULT_MAX_FEEDRATE * 2 #if ENABLED(LIMITED_MAX_FR_EDITING) @@ -1189,7 +1193,7 @@ * Override with M201 * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] */ -#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 3000, 3000 } //{ 3000, 3000, 100, 10000 } +#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 3000, 3000, 3000 } //{ 3000, 3000, 100, 10000 } //#define LIMITED_MAX_ACCEL_EDITING // Limit edit via M201 or LCD to DEFAULT_MAX_ACCELERATION * 2 #if ENABLED(LIMITED_MAX_ACCEL_EDITING) @@ -1611,7 +1615,7 @@ #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders -//#define I_ENABLE_ON 0 +#define I_ENABLE_ON 0 //#define J_ENABLE_ON 0 //#define K_ENABLE_ON 0 //#define U_ENABLE_ON 0 @@ -1623,7 +1627,7 @@ #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false -//#define DISABLE_I false +#define DISABLE_I false //#define DISABLE_J false //#define DISABLE_K false //#define DISABLE_U false @@ -1644,7 +1648,7 @@ #define INVERT_X_DIR true //false #define INVERT_Y_DIR true //false #define INVERT_Z_DIR false -//#define INVERT_I_DIR false +#define INVERT_I_DIR false //#define INVERT_J_DIR false //#define INVERT_K_DIR false //#define INVERT_U_DIR false @@ -1685,7 +1689,7 @@ #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 -//#define I_HOME_DIR -1 +#define I_HOME_DIR -1 //#define J_HOME_DIR -1 //#define K_HOME_DIR -1 //#define U_HOME_DIR -1 @@ -1705,8 +1709,8 @@ #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 1000 // 200 -//#define I_MIN_POS 0 -//#define I_MAX_POS 50 +#define I_MIN_POS 0 +#define I_MAX_POS 50 //#define J_MIN_POS 0 //#define J_MAX_POS 50 //#define K_MIN_POS 0 @@ -2099,7 +2103,7 @@ #endif // Homing speeds (linear=mm/min, rotational=°/min) -#define HOMING_FEEDRATE_MM_M { (50*60), (50*60), (50*60) } +#define HOMING_FEEDRATE_MM_M { (50*60), (50*60), (50*60), (50*60) } // Validate that endstops are triggered on homing moves #define VALIDATE_HOMING_ENDSTOPS diff --git a/Marlin/Configuration_adv.h b/Marlin/Configuration_adv.h index b3ba8f4919..fae97494b5 100644 --- a/Marlin/Configuration_adv.h +++ b/Marlin/Configuration_adv.h @@ -877,8 +877,8 @@ //#define SENSORLESS_BACKOFF_MM { 2, 2, 0 } // (linear=mm, rotational=°) Backoff from endstops before sensorless homing -#define HOMING_BUMP_MM { 5, 5, 2 } // (linear=mm, rotational=°) Backoff from endstops after first bump -#define HOMING_BUMP_DIVISOR { 2, 2, 4 } // Re-Bump Speed Divisor (Divides the Homing Feedrate) +#define HOMING_BUMP_MM { 5, 5, 2, 2 } // (linear=mm, rotational=°) Backoff from endstops after first bump +#define HOMING_BUMP_DIVISOR { 2, 2, 4, 4 } // Re-Bump Speed Divisor (Divides the Homing Feedrate) //#define HOMING_BACKOFF_POST_MM { 2, 2, 2 } // (linear=mm, rotational=°) Backoff from endstops after homing //#define XY_COUNTERPART_BACKOFF_MM 0 // (mm) Backoff X after homing Y, and vice-versa @@ -1095,7 +1095,7 @@ //#define SHAPING_MENU // Add a menu to the LCD to set shaping parameters. #endif -#define AXIS_RELATIVE_MODES { false, false, false, false } +#define AXIS_RELATIVE_MODES { false, false, false, false, false } // Add a Duplicate option for well-separated conjoined nozzles //#define MULTI_NOZZLE_DUPLICATION @@ -1345,7 +1345,7 @@ // @section lcd #if HAS_MANUAL_MOVE_MENU - #define MANUAL_FEEDRATE { 50*60, 50*60, 4*60, 2*60 } // (mm/min) Feedrates for manual moves along X, Y, Z, E from panel + #define MANUAL_FEEDRATE { 50*60, 50*60, 4*60, 2*60, 2*60 } // (mm/min) Feedrates for manual moves along X, Y, Z, E from panel #define FINE_MANUAL_MOVE 0.025 // (mm) Smallest manual move (< 0.1mm) applying to Z on most machines #if IS_ULTIPANEL #define MANUAL_E_MOVES_RELATIVE // Display extruder move distance rather than "position"
Re: Marlin 2.1.2.1 Config: 2 Hotend loops, one Extruder, reasighn E1 to U pins February 03, 2024 06:16PM |
