RAMPS with higher than 15A power supply August 07, 2011 09:21PM |
RAMPS 1.2
powering the heated bed directly form the main PSU, grounding on the RAMPS
connect + from the PSU to the power plug of the RAMPS; connect the bed directly to the main power +, connect the other side of the bed (ground) to - on the RAMPS (D8) cause the mosfet is just switching the bed on and off it is barely getting hot and can handle the power pretty well.
Re: RAMPS with higher than 15A power supply August 07, 2011 11:39PM |
Re: RAMPS with higher than 15A power supply August 08, 2011 12:34AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: RAMPS with higher than 15A power supply August 08, 2011 07:47AM |
Re: RAMPS with higher than 15A power supply August 08, 2011 08:53AM |
