RAMPS 1.4 no heating
Posted by sack
July 16, 2012 07:48AM
I set up a 1.4 Board with Arduino 2560 Mega and Sprinter-FW. Actually movements, endstops & fan works fine, temperature reading is fine as well, but I'm not able to switch any heating on (no extruder, nor heating bed). The LEDs keep dark, too. I'm connecting via serial monitor and send something like
M104 100
and the extruder should heat up to 100°C, correct? Well, it doesn't.
Any thoughts?
Re: RAMPS 1.4 no heating
July 16, 2012 08:05AM
Probably your pin assignments.
July 16, 2012 09:34AM
which pin assignments? At least the LEDs should light up, right?
July 16, 2012 11:54AM
Only if you have the correct pins mapped in the firmware.
II haven't used Sprinter, but I'd start by checking configuration.h then pins.h
July 17, 2012 12:36AM
In pins.h there should be a selection for RAMPS pre 1.3, and 1.3/1.4
Probably you have not set these.
July 17, 2012 02:09AM
no, everything was fine, I hat to send >M104 S 100< for setting the extruder temperature (I was missing the >S< ). Next task is to get it to work with ReplicatorG, I'm on a Mac, is there any Howto or any better alternative tool? R.G is working somehow, but not fully.
Thanks so far.
July 17, 2012 12:14PM
On the Mac I use repetier host, it have a version of Slic3r built in.
Though more recently I've been slicing in KisSlicer and just using repetier host to control the printer, since I prefer it to the more commonly used Pronterface..
