I built my 3D printer a little over a year ago and over that time, I ran into some issues and performed upgrades to correct them all the while running into a bit of bad luck over the next year. My computer died, my hot end was junk, I changed extruders all around the time I fought for custody of my kids, got married and moved into a house. Needless to say, I got pretty busy. Finally, I got some free time again and attempted to get my machine back up and running.
I never did get the chance to fully setup my new extruder, so I made the necessary adjustments and attempted to compile and upload. I got an error. Was it the Windows 8 update since I last touched this about a year ago? Or was it all done on my old computer that died and I didn't have this one all setup?
After what seemed like a good hundred attempts, I gave up on Sprinter and tried Repetier. This was great, I was able to edit all of my settings in a nice simple web interface that I could manage even after knocking back a few. Better yet, It compiled and successfully uploaded.
So I fired everything up again and found that the extruder I had put together wasn't applying enough force on the filament. I'm now living in a small town and finding metric hardware sin't easy. So instead of ordering more bits and pieces of things I ordered what looked like a good solid complete extruder and impatiently waited for it to arrive. Finally after a few days it showed up in my mailbox and I went back to work. The stepper for the extruder is a geared Kysan 1040220. The same brand as my other non-geared steppers and same color coding. After wiring it together and tidying it all up, I loaded up Repetier and attempted to test out the extruder. No good. I couldn't connect to my printer. I tried good ole Pronterface and was able to connect. I first checked axis X, Y and Z. All good. Then I tried the extruder. Nothing. So I made a few adjustments and it was jerking around a bit back and forth.
Was the wiring different? I looked at the schematics and tested with a multimeter and found that it was all good. I checked everything to make sure it was all good by swapping steppers. Everything seemed good except for the E0 extruder. I connected it to the X axis and I was able to get it to move properly. Maybe E0 got shorted out or a solder point got loose after the move. I don't know, I'm losing patience and my wife probably isn't so thrilled about me dumping more money into this thing. I remapped the pins to use E1 and nothing still.
I thought it had to be the firmware version I managed to grab and I didn't have every little detail right. I mean I tried every little setting for extrusion that I could. I decided to go back to Sprinter because I did have that all working at one point, but I could not compile it at all. I would get so many different errors and I look at enough code during the day for work I wasn't even going to try do dig in too far. It seems to work for everybody else, right? I tried every version of Arduino and would get a different error with each one. Maybe it is this lemon laptop I bought. So at work, we have Windows 7. I decided to download Arduino .23, grabbed the latest GIT of Sprinter and opened it up. I got an error compiling, but I forgot to switch to Arduino Mega. I made the switch and successfully compiled. I then zipped up everything so I could pull it up at home.
I got home later that same night and downloaded the files from my cloud account. I happily unzipped the files and opened it all up. I made sure to select Arduino Mega this time and clicked compile. Curses! I'm getting errors again! Just when I was about to take a hammer and destroy this blasted computer once and for all, I thought I'd try one more thing. When I was at work, I first had Uno selected before compiling for Mega. I selected Uno, clicked to compile, got the error saying I should select Mega, I selected Mega and compiled...successfully. I am now as happy as a little girl. I was able to fully control every axis and extruder from Pronterface. My wife can relax about where the money is going and I can resume making things.
It was a long story, but I'm sure some can relate to all of the trial and error. The short of it is if you're having trouble compiling with a Windows 8 computer, try first compiling for Uno, then Mega.
