Rambo Power Questions
Posted by Marty56
October 30, 2014 12:48PM
To my understanding, the RAMBO board has separate power inputs for the bed, mosfets, as well as the motors and logic. Would it be possible to supply different voltages to each of the power inputs?
For example, could I supply 12 or 24V to the logic power input while supplying 5V to the mosfet input?
Also, the fan outputs on RAMBO are also mosfet controlled correct? I would be able to use a fan at variable speeds from each output instead of just being able to turn a fan off and on?
Re: Rambo Power Questions
October 30, 2014 03:09PM
Marty56
Yes
Minimum voltage is 12V. Maximum is 24 (v1.0-1.1) or 35 (v1.2) The 5V for the microcontroller is regulated down via a switching mode power supply from either the motor power (v1-1.1) or extruder/fan (v1.2). You don't have to supply the 5V.
Yes
Yes, just set the duty cycle for that pin in your firmware to the speed you want.
