Auto Bed Levelling - End Stop installation February 03, 2015 02:41PM |
#define Z_PROBE_OFFSET {0, 10, -5.6, 0} // X, Y, Z, E distance between hotend nozzle and deployed bed leveling probe. #define Z_PROBE_DEPLOY_START_LOCATION {-40, -25, 30, 0} // X, Y, Z, E start location for z-probe deployment sequence #define Z_PROBE_DEPLOY_END_LOCATION {0, -25, 30, 0} // X, Y, Z, E end location for z-probe deployment sequence #define Z_PROBE_RETRACT_START_LOCATION {40, -25, 20, 0} // X, Y, Z, E start location for z-probe retract sequence #define Z_PROBE_RETRACT_END_LOCATION {0, 50, 1, 0} // X, Y, Z, E end location for z-probe retract sequence // ... #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command #define SERVO_ENDSTOPS {-1, -1, 0} // Servo index for X, Y, Z. Disable with -1 #define SERVO_ENDSTOP_ANGLES {0,0, 0,0, 165,65} // X,Y,Z Axis Extend and Retract angles
Re: Auto Bed Levelling - End Stop installation February 03, 2015 03:13PM |
#ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN <---- this was commented #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. <--- this was set to true const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS <---- this was uncommented
Re: Auto Bed Levelling - End Stop installation February 05, 2015 12:15PM |
Re: Auto Bed Levelling - End Stop installation February 07, 2015 10:51AM |
