Hello
I'm trying to use the Move Axis option to move the axis manualy but nothing happens. The value of the postion of the axis changes on the lcd screen perfectly but the stepper motors do not turn.. I have tried to upload the test program to test if there is a problem with my stepper motors, but it worked perfectly.
I'm using a Mega 2560 + Ramps 1.4 + RepRapDiscount Full Graphic Smart Controller.
Firmware: Marlin Development
The only thing I changed in the software is remove the // in //#RepRapDiscount_Full_Graphic_Smart_Controller
edit1: I also found out that the voltage on the Dir pin changes when I try to use the Move Axis option but the voltage on the Step pin remains the same.
Edited 2 time(s). Last edit at 04/14/2015 06:38AM by MrWizz.
