Powering 30A 12v Heatbed with a mosfet June 23, 2016 01:31AM |
Re: Powering 30A 12v Heatbed with a mosfet June 24, 2016 11:28AM |
Re: Powering 30A 12v Heatbed with a mosfet June 24, 2016 12:39PM |
LarsK
I have the exact same question here:
[forums.reprap.org]
I am going to put 3 mosfets in parallel. I plan on making the circuit this weekend so keep an eye on that thread for my experience.
I think your chosen MOSFET will need to be run at 10V or higher to get the required performance. If you look at page 3 figure nr. 7 you see that you are almost in the flat region at 30A with 5V gate voltage. This means you get a really high voltage drop at 30A which in turn means your mosfet heats. You need a V(gs) of 8V.. Mosfets are not on/off switches that works at the gate thresshold voltage. If you want to transfer serious currents you need to be well above that value.
Disclaimer: I am not electronic expert. I only "really" started learning about Mosfets the other day when I made that post. The above is my best understanding.
Re: Powering 30A 12v Heatbed with a mosfet June 25, 2016 04:49PM |
Re: Powering 30A 12v Heatbed with a mosfet June 25, 2016 04:55PM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 02:00AM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 11:49AM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 01:15PM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 01:37PM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 04:09PM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 05:58PM |
Re: Powering 30A 12v Heatbed with a mosfet June 26, 2016 09:43PM |
dc42
A few comments:
1. For bed heaters larger than 200 x 200mm, it is much easier to use 24V power and halve the bed current than to stay with 12V and have to wire for very large currents. But a standard RAMPS doesn't give you that option. Preferably, upgrade to 24V-capable electronics. If you don't want to do that, using two separate PSUS (24V for the bed heater and 12V for everything else) with your RAMPS is a reasonable option.
2. For really large beds, mains voltage bed heaters are the way to go, switched by an inexpensive zero crossing DC-AC SSR. The Fotek ones are OK for this. But of course you need to take extra safety precautions.
3. That TI mosfet does appear to have very good specifications. But in practice, it's the PCB trace widths and other wiring that are the limiting factor, not usually the mosfet, unless you choose a particularly poor mosfet such as you find on most but not all RAMPS boards.
Re: Powering 30A 12v Heatbed with a mosfet July 06, 2016 08:10AM |
Re: Powering 30A 12v Heatbed with a mosfet July 06, 2016 11:54AM |
Admin Registered: 16 years ago Posts: 13,909 |
Re: Powering 30A 12v Heatbed with a mosfet August 23, 2016 07:39AM |
Re: Powering 30A 12v Heatbed with a mosfet August 23, 2016 03:22PM |
dc42
4. There are a couple of relatively inexpensive SSRs that don't suffer from the problem (high voltage drop) of the so-called Fotek SSR-40DD (which you won't find listed on Fotek's datasheet). One is the Power Expander from reprap.me. The other is a conventional 4-terminal SSR from a company in the USA. I haven't been able to find it recently, but I think the manufacturer begins with the letter A.
Re: Powering 30A 12v Heatbed with a mosfet September 14, 2016 08:45PM |
Re: Powering 30A 12v Heatbed with a mosfet September 23, 2016 02:07PM |
Re: Powering 30A 12v Heatbed with a mosfet September 23, 2016 09:00PM |
