Hi guys,
Chronic printing issues caused me to have replace the stepper feet on my cherry Pi Delta printer which were crumbling apart, this called for the electronics to be pulled apart and so I've rewired like i think it should be.
The bed heats up
The extruder heats up
and most steppers "at least" seem to work, BUT trying to "home" in repeiter does not work as it should do.
I can move the motors up down left right, but it also seems they're not moving in the right direction all the time. When Homing correctly, all three axis move up at the same time but currently only the X arm is trying to home causing the rods to pop out as they do when you move out of the print area.
I can't seem to find any documentation or leads on this issue so I come to the forums to see if someone else has encountered this. My next step will be to buy a new ramps/arduino and start fresh which I hope I don't have to.
Thanks very much!
James
Edited 1 time(s). Last edit at 01/13/2017 09:42AM by pringleman.
