Trinamic Driver Firmware Problem February 21, 2018 04:26PM |
Arduino: 1.8.4 (Mac OS X), Board: "RAMBo"
In file included from sketch/pins.h:146:0,
from sketch/MarlinConfig.h:33,
from /Users/Scrappy/Desktop/Life/Projects/3D Printer/Util/Marlin_Einsy_1.1.5/Marlin_Einsy_1.1.5.ino:31:
sketch/pins_EINSYRAMBO.h:46:0: warning: "R_SENSE" redefined
#define R_SENSE 0.22
In file included from sketch/MarlinConfig.h:32:0,
sketch/Configuration_adv.h:943:0: note: this is the location of the previous definition
#define R_SENSE 0.11 // R_sense resistor for SilentStepStick2130
Sketch uses 126406 bytes (48%) of program storage space. Maximum is 258048 bytes.
Global variables use 5220 bytes of dynamic memory.
Re: Trinamic Driver Firmware Problem February 21, 2018 05:05PM |
Admin Registered: 13 years ago Posts: 7,004 |
Re: Trinamic Driver Firmware Problem February 22, 2018 05:07PM |
sketch/Marlin_main.cpp:9851:15: warning: 'tmc2130_set_pwmthrs' defined but not used [-Wunused-function]
static void tmc2130_set_pwmthrs(TMC2130Stepper &st, const char name, const int32_t thrs, const uint32_t spmm) {
sketch/Marlin_main.cpp:9861:15: warning: 'tmc2130_set_sgt' defined but not used [-Wunused-function]
static void tmc2130_set_sgt(TMC2130Stepper &st, const char name, const int8_t sgt_val) {
In file included from sketch/fastio.h:33:0,
from sketch/MarlinConfig.h:26,
from sketch/Marlin.h:36,
from sketch/stepper.cpp:47:
sketch/stepper.cpp: In static member function 'static void Stepper::digipot_current(uint8_t, int)':
sketch/macros.h:126:28: warning: comparison is always true due to limited range of data type [-Wtype-limits]
#define WITHIN(V,L,H) ((V) >= (L) && (V) <= (H))
sketch/stepper.cpp:1512:11: note: in expansion of macro 'WITHIN'
if (WITHIN(driver, 0, 2))
sketch/stepper_indirection.cpp:174:83: warning: unused parameter 'thrs' [-Wunused-parameter]
void tmc2130_init(TMC2130Stepper &st, const uint16_t microsteps, const uint32_t thrs, const float &spmm) {
sketch/stepper_indirection.cpp:174:102: warning: unused parameter 'spmm' [-Wunused-parameter]
Re: Trinamic Driver Firmware Problem February 22, 2018 09:05PM |
