Help please Ramps 1.4 XY issues March 31, 2015 11:24AM |
Re: Help please Ramps 1.4 XY issues March 31, 2015 12:26PM |
ITWhiz
OK this might need some explaining.
Setup
Home built frame
Nema 17 motors,
Threaded rod X, Y & Z
Arduino Mega
Ramps 1.4 (Ebay cheapy)
A4988 drivers ( 3 off X,Y & Z)
Firmware - Marlin (with changes for setup, Configuration.h attached [attachment 52040 Configuration.h])
PC side - PronterFace
Home built 3D Printer/CNC machine which was nearly working
Z was a bit jerky, X & Y were fine.
NOW, after some adjustments
Z perfect, X & Y dead.
I think I fried the X & Y drivers by adjusting them too much and now they won't work but Z does.
I was hoping to finish setting up the board with the remaining driver while some more were in the post
BUT
If I try each motor on the Z driver/port on the Ramps board they work fine.
If I move the working driver to the Y position on the board and try the motors they just about move and are jerky and wont move correctly, same with the X postion.
Any ideas why when the driver board is in the Z position all motors work, but in X or Y position none of them work, could I have a setting wrong in configuration.h, or completely blown my boards ?
Re: Help please Ramps 1.4 XY issues March 31, 2015 02:21PM |
Re: Help please Ramps 1.4 XY issues March 31, 2015 07:19PM |
Re: Help please Ramps 1.4 XY issues April 01, 2015 03:10AM |
ITWhiz
Hi all ,
Thanks for the replies so far
Yes all jumpers are inplace under the driver boards, the 3 steppers are
Xaxis - 17PM-K502-G1ST (4 wire)
Yaxis - EM-233 STP-42D135-01 (5 wires but only using 4 outer)
Zaxis - EM-233 STP-42D135-01 (5 wires but only using 4 outer)
As mentioned before
If I leave the driver board in the Z Slot and connect each Stepper to the Z they all work perfectly, and the steps per mm are spot on perfect, but moving the driverboard to X or Y they do not work.
The original stepper driver boards for X & Y I think are blown as even the Arduino will not work if these are plugged in.
I've removed the load from the stepper (disconnected the threaded bar) and they still don't work on the X or Y.
All the steps per mm are set the same (2650), which I've calibrated on the Z axis as being spot on.
The Z Jerk is set as 0.4,
and I did set the X/Y Jerk to the same, I'm now thinking this may be wrong, but as all the threaded bars are the same then why shouldn't it be the same.
Re: Help please Ramps 1.4 XY issues April 01, 2015 03:50AM |
Re: Help please Ramps 1.4 XY issues April 01, 2015 04:35AM |
ITWhiz
Hi again
From the text above
'If I leave the driver board in the Z Slot and connect each Stepper to the Z they all work perfectly, and the steps per mm are spot on perfect, but moving the driverboard to X or Y they do not work.'
I've tried all the combinations of swapping driver boards and motors, but still can't understand if I use the last working driver board in any position it only works in the Z slot.
The only other thing I thought of is is the RAMPS jumpers are set to 1/16 steps but the Marlin software is set to something different.
Is there somewhere in the Marlin configuration files that sets the step increments i.e 1/4,1/8, 1/16 etc
Re: Help please Ramps 1.4 XY issues April 01, 2015 04:52AM |
Re: Help please Ramps 1.4 XY issues May 31, 2015 10:25PM |
Re: Help please Ramps 1.4 XY issues June 01, 2015 05:00AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: Help please Ramps 1.4 XY issues March 14, 2018 10:50AM |
Re: Help please Ramps 1.4 XY issues March 14, 2018 09:31PM |
