Dear RepRap forum members,
I would like to run my Nema 17 motors connected to
Arduino Mega 2560+
Ramps 1.6+
Drv8825 with the
AccelStepper library.
I have the mechanical connections set properly as I can run my motors by using Marlin.
I want to move the motors without using Marlin, I want to do this directly from
AccelStepper.
To this end I have checked the file
Marlin\src\pins\ramps\pins_RAMPS.h and got
// Steppers
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#ifndef X_CS_PIN
#define X_CS_PIN 53
#endif
Then, I tried to use this and run my x-motor with the following code.
// Include the AccelStepper Library
//#include (AccelStepper.h) //Correct Parenthesis
// Define motor interface type
#define MotorInterfaceType 1
// Creates an instance
AccelStepper myStepper(MotorInterfaceType,X_STEP_PIN,X_DIR_PIN);
void setup() {
// set the maximum speed, acceleration factor,
// initial speed and the target position
pinMode(X_ENABLE_PIN,OUTPUT);
digitalWrite(X_ENABLE_PIN,LOW);
// myStepper.setCurrent(0);
// myStepper.setMaxSpeed(1000);
myStepper.setAcceleration(2000);
myStepper.setSpeed(1000);
myStepper.moveTo(1600);
void loop() {
// Change direction once the motor reaches target position
if (myStepper.distanceToGo() == 0)
myStepper.moveTo(-myStepper.currentPosition());
// Move the motor one step
myStepper.run();
But, I dont see any movement. What do you think can be the problem?
Thank you.
bkarpuz
Edited 1 time(s). Last edit at 05/20/2023 06:49PM by bkarpuz.
