Possibly broken RAMPS?
Posted by Pieter
June 17, 2013 11:19AM
So I bought a ramps 1.4 sometime ago with 4 polulus.
Tested it out on the replicator and it detected it successfully.
Took one of my PSU's and cut the yellow and black wire and attached it.
There is a problem though. connecting the power to the 11amps power connector will have the power supply running but when I connect it to the 5amps connector the power supply shuts off.
Is my RAMPS faulty?
Edit: Problem solved! replaced the 1n400x diode and all is working!
Edited 2 time(s). Last edit at 06/17/2013 02:09PM by Pieter.
