Reset brought to pin header?
Posted by CapnBry
June 17, 2013 01:45PM
My RAMPS board isn't very accessible so I was looking to bring the reset button out to the control panel. Looking at the board I can't find any header that the reset line is tied to. Am I overlooking it somewhere? It is trivial to solder some wires to the board, but I'd prefer to use a pin header to make it easier to remove the board if needed.
Re: Reset brought to pin header?
June 17, 2013 04:40PM
I haven't looked that closely, but when I followed tommyc's directions to wire up my control panel, I had to solder directly to the reset switch. I put a single wire connector in the wire itself so that I can easily disconnect if necessary (and it has been necessary a few times)
