How to set up the 5th pololu to power the 2nd z stepper
Posted by pwaisberg
June 21, 2013 04:26PM
Well it may be a dumb question, but...
Is there a way to setup Marlin so I can use the 5th pololu to power up the 2nd Z stepper, so I can run them colder?
Thanks!!!
Re: How to set up the 5th pololu to power the 2nd z stepper
June 21, 2013 07:08PM
Yup. In Configuration_adv.h at line 148 uncomment #define Z_DUAL_STEPPER_DRIVERS. This is assuming you're using RAMPS. If you read the comment, the pins are only defined for RAMPS boards, so you can make it work with other ones, you'll just have to slog through some code.
