Who has RAMPSv1.3?? June 20, 2011 06:48AM |
Re: Who has RAMPSv1.3?? June 20, 2011 07:09AM |
Re: Who has RAMPSv1.3?? June 20, 2011 10:52AM |
Re: Who has RAMPSv1.3?? June 20, 2011 02:41PM |
Re: Who has RAMPSv1.3?? June 20, 2011 07:07PM |
#define OPTO_PULLUPS_INTERNAL 1
#define E_STEP_PIN 26 #define E_DIR_PIN 28 #define E_ENABLE_PIN 24
Re: Who has RAMPSv1.3?? June 20, 2011 10:58PM |
Re: Who has RAMPSv1.3?? June 20, 2011 11:05PM |
Re: Who has RAMPSv1.3?? June 20, 2011 11:44PM |
Re: Who has RAMPSv1.3?? June 21, 2011 05:59AM |
Re: Who has RAMPSv1.3?? June 21, 2011 07:30AM |
I'm still not able to connect to Repsnapper, I just click on connect to printer and the light on that button I click goes on for a few moments and then turns off, but the ramps light flashes in sequence and there is holding torque. Man, I'm lost on this one, need help from higher source it seems
Re: Who has RAMPSv1.3?? June 21, 2011 07:59AM |
Re: Who has RAMPSv1.3?? June 21, 2011 09:15AM |
Re: Who has RAMPSv1.3?? June 21, 2011 10:04AM |
Re: Who has RAMPSv1.3?? June 21, 2011 03:20PM |
Re: Who has RAMPSv1.3?? June 21, 2011 04:11PM |
Re: Who has RAMPSv1.3?? June 21, 2011 05:33PM |
Re: Who has RAMPSv1.3?? June 21, 2011 06:45PM |
#define X_ENDSTOP_INVERTING 0 #define Y_ENDSTOP_INVERTING 0 #define Z_ENDSTOP_INVERTING 0in your configuration.h in the ramps section (if they're already there, just change them), or if that doesn't work, try setting them to 1
Re: Who has RAMPSv1.3?? June 21, 2011 08:44PM |
Re: Who has RAMPSv1.3?? June 21, 2011 09:54PM |
Re: Who has RAMPSv1.3?? June 22, 2011 12:08AM |
Re: Who has RAMPSv1.3?? July 04, 2011 09:08AM |
// Heated bed #define BED_HEATER_PIN (byte)8 #define BED_TEMPERATURE_PIN (byte) 68 //extruder pins #define EXTRUDER_0_STEP_PIN (byte)26 #define EXTRUDER_0_DIR_PIN (byte)28 #define EXTRUDER_0_ENABLE_PIN (byte)24 #define EXTRUDER_0_HEATER_PIN (byte)10 #define EXTRUDER_0_TEMPERATURE_PIN (byte)67 #define EXTRUDER_1_STEP_PIN (byte)36 #define EXTRUDER_1_DIR_PIN (byte)34 #define EXTRUDER_1_ENABLE_PIN (byte)30 #define EXTRUDER_1_HEATER_PIN (byte)9 #define EXTRUDER_1_TEMPERATURE_PIN (byte)69
/******************************************** * Arduino Mega motherboard */ #if EXTRUDER_CONTROLLER == EXTRUDER_CONTROLLER_INTERNAL static PIDcontrol ePID(EXTRUDER_0_HEATER_PIN, EXTRUDER_0_TEMPERATURE_PIN, false);because ePID is static and used for both extruders, the PID will never end up using EXTRUDER_1_TEMPERATURE_PIN
