Howto Supportmaterial? 18. March 2012 05:14 |
Administrator Registrierungsdatum: 12 Jahre zuvor Beiträge: 819 |
Activate Raft True Add Raft, Elevate Nozzle, Orbit: True Base Feed Rate Multiplier (ratio): 1.0 Base Flow Rate Multiplier (ratio): 1.0 Base Infill Density (ratio): 0.5 Base Layer Thickness over Layer Thickness: 2.0 Base Layers (integer): 0 Base Nozzle Lift over Base Layer Thickness (ratio): 0.4 Initial Circling: True Infill Overhang over Extrusion Width (ratio): 0.05 Interface Feed Rate Multiplier (ratio): 0.5 Interface Flow Rate Multiplier (ratio): 0.5 Interface Infill Density (ratio): 0.5 Interface Layer Thickness over Layer Thickness: 1.0 Interface Layers (integer): 0 Interface Nozzle Lift over Interface Layer Thickness (ratio): 0.5 Name of Support End File: support_end.gcode Name of Support Start File: support_start.gcode Operating Nozzle Lift over Layer Thickness (ratio): 0.5 Raft Additional Margin over Length (%): 1.0 Raft Margin (mm): 2.0 Support Cross Hatch False Support Flow Rate over Operating Flow Rate (ratio): 0.8 Support Gap over Perimeter Extrusion Width (ratio): 0.8 None False Empty Layers Only False Everywhere True Exterior Only False Support Minimum Angle (degrees): 60.0
Re: Howto Supportmaterial? 18. March 2012 06:21 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 3.742 |
Re: Howto Supportmaterial? 18. March 2012 06:30 |
Re: Howto Supportmaterial? 19. March 2012 14:25 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 7.505 |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: Howto Supportmaterial? 19. March 2012 14:46 |
Re: Howto Supportmaterial? 19. March 2012 15:26 |
Re: Howto Supportmaterial? 19. March 2012 15:38 |
Re: Howto Supportmaterial? 20. March 2012 01:19 |
Re: Howto Supportmaterial? 20. March 2012 04:26 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.902 |
Re: Howto Supportmaterial? 20. March 2012 20:19 |
