Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 19. April 2015 08:01 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 106 |
Re: Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 19. April 2015 08:14 |
# generated by Slic3r 1.1.7 on Sun Apr 19 11:42:05 2015
avoid_crossing_perimeters = 0
bed_size = 190,190
bed_temperature = 60
bottom_solid_layers = 4
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 3
dont_support_bridges = 1
duplicate_distance = 6
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors\n
external_perimeter_speed = 70%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 0.8
extrusion_width = 0.4
fan_always_on = 1
fan_below_layer_time = 60
filament_diameter = 1.8
fill_angle = 45
fill_density = 15%
fill_pattern = honeycomb
first_layer_acceleration = 0
first_layer_bed_temperature = 60
first_layer_extrusion_width = 150%
first_layer_height = 0.2
first_layer_speed = 20
first_layer_temperature = 220
g0 = 0
gap_fill_speed = 15
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 80
interface_shells = 0
layer_gcode =
layer_height = 0.2
max_fan_speed = 100
min_fan_speed = 100
min_print_speed = 10
min_skirt_length = 10
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 60
perimeters = 4
post_process =
print_center = 95,95
raft_layers = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 0
retract_length = 0.8
retract_length_toolchange = 10
retract_lift = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 20
seam_position = random
skirt_distance = 10
skirt_height = 1
skirts = 2
slowdown_below_layer_time = 60
small_perimeter_speed = 10
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 60
spiral_vase = 0
standby_temperature_delta = -5
start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n
support_material = 0
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = pillars
support_material_spacing = 3
support_material_speed = 80
support_material_threshold = 0
temperature = 215
thin_walls = 1
threads = 1
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 60%
top_solid_layers = 4
travel_speed = 150
use_firmware_retraction = 0
use_relative_e_distances = 0
vibration_limit = 0
wipe = 0
z_offset = -0.05
Re: Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 19. April 2015 08:15 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 571 |
Re: Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 19. April 2015 08:20 |
Re: Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 19. April 2015 15:44 |
Re: Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 25. April 2015 01:58 |
Re: Diverse Probleme (Sparkcube - Löcher im Infill, keine ausreichende Kühlung) 25. April 2015 05:18 |
