Extruder hört nach Start auf zu Heizen, vielleicht G-Code Probleme? 13. June 2016 15:49 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 422 |
; G-Code generated by Simplify3D(R) Version 3.0.2 ; Jun 13, 2016 at 10:57:44 ; Settings Summary ; processName,Process1 ; applyToModels,Quader-190-20-1,5 ; profileName,master thesis 1 (modified) ; profileVersion,2016-05-03 12:58:56 ; baseProfile,Default ; printMaterial, ; printQuality, ; printExtruders, ; extruderName,Extruder 1 ; extruderToolheadNumber,0 ; extruderDiameter,1 ; extruderAutoWidth,0 ; extruderWidth,1 ; extrusionMultiplier,1 ; extruderUseRetract,1 ; extruderRetractionDistance,0.5 ; extruderExtraRestartDistance,0 ; extruderRetractionZLift,0 ; extruderRetractionSpeed,2400 ; extruderUseCoasting,1 ; extruderCoastingDistance,0.2 ; extruderUseWipe,1 ; extruderWipeDistance,2 ; primaryExtruder,0 ; layerHeight,0.5 ; topSolidLayers,0 ; bottomSolidLayers,0 ; perimeterOutlines,0 ; printPerimetersInsideOut,1 ; startPointOption,3 ; startPointOriginX,200 ; startPointOriginY,0 ; startPointOriginZ,200 ; sequentialIslands,0 ; spiralVaseMode,0 ; firstLayerHeightPercentage,100 ; firstLayerWidthPercentage,100 ; firstLayerUnderspeed,0.5 ; useRaft,0 ; raftExtruder,0 ; raftLayers,3 ; raftOffset,3 ; raftSeparationDistance,0.14 ; raftInfill,85 ; disableRaftBaseLayers,0 ; useSkirt,0 ; skirtExtruder,0 ; skirtLayers,1 ; skirtOutlines,1 ; skirtOffset,1 ; usePrimePillar,0 ; primePillarExtruder,999 ; primePillarWidth,12 ; primePillarLocation,7 ; primePillarSpeedMultiplier,1 ; useOozeShield,0 ; oozeShieldExtruder,999 ; oozeShieldOffset,2 ; oozeShieldOutlines,1 ; oozeShieldSidewallShape,1 ; oozeShieldSidewallAngle,30 ; oozeShieldSpeedMultiplier,1 ; infillExtruder,0 ; internalInfillPattern,Rectilinear ; externalInfillPattern,Rectilinear ; infillPercentage,100 ; outlineOverlapPercentage,15 ; infillExtrusionWidthPercentage,125 ; minInfillLength,5 ; infillLayerInterval,1 ; infillAngles,0 ; overlapInfillAngles,0 ; generateSupport,0 ; supportExtruder,0 ; supportInfillPercentage,20 ; supportExtraInflation,0 ; denseSupportLayers,0 ; denseSupportInfillPercentage,40 ; supportLayerInterval,1 ; supportHorizontalPartOffset,1 ; supportUpperSeparationLayers,2 ; supportLowerSeparationLayers,2 ; supportType,0 ; supportGridSpacing,4 ; maxOverhangAngle,60 ; supportAngles,0 ; temperatureName,Extruder 1 Temperature ; temperatureNumber,0 ; temperatureSetpointCount,1 ; temperatureSetpointLayers,1 ; temperatureSetpointTemperatures,245 ; temperatureStabilizeAtStartup,1 ; temperatureHeatedBed,0 ; temperatureRelayBetweenLayers,0 ; temperatureRelayBetweenLoops,0 ; fanLayers,1 ; fanSpeeds,0 ; blipFanToFullPower,1 ; adjustSpeedForCooling,1 ; minSpeedLayerTime,5 ; minCoolingSpeedSlowdown,20 ; increaseFanForCooling,0 ; minFanLayerTime,45 ; maxCoolingFanSpeed,100 ; increaseFanForBridging,0 ; bridgingFanSpeed,100 ; use5D,1 ; relativeEdistances,0 ; allowEaxisZeroing,1 ; independentExtruderAxes,0 ; includeM10123,0 ; stickySupport,1 ; applyToolheadOffsets,0 ; gcodeXoffset,0 ; gcodeYoffset,0 ; gcodeZoffset,0 ; overrideMachineDefinition,0 ; machineTypeOverride,0 ; strokeXoverride,200 ; strokeYoverride,200 ; strokeZoverride,200 ; originOffsetXoverride,0 ; originOffsetYoverride,0 ; originOffsetZoverride,0 ; homeXdirOverride,-1 ; homeYdirOverride,-1 ; homeZdirOverride,-1 ; flipXoverride,1 ; flipYoverride,-1 ; flipZoverride,1 ; toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0 ; overrideFirmwareConfiguration,0 ; firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter) ; GPXconfigOverride,r2 ; baudRateOverride,115200 ; overridePrinterModels,0 ; printerModelsOverride ; startingGcode,;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line,;M109 S{print_temperature} ;Uncomment to add your own temperature line,G21 ;metric values,G90 ;absolute positioning,M82 ;set extruder to absolute mode,M107 ;start with the fan off,G28 X0 Y0 ;move X/Y to min endstops,G28 Z0 ;move Z to min endstops,G1 Z5.0 F1500 ;move the platform down 15mm,G1 Z0 ;move extruder to 0,G92 E0 ;zero the extruded length,G1 F900 E20 ;extrude 10mm of feed stock,G92 E0 ;zero the extruded length again,G1 F{travel_speed},M117 Leave me alone!... ;Put printing message on LCD screen ; layerChangeGcode, ; retractionGcode, ; toolChangeGcode, ; endingGcode,;End GCode,M104 S0 ;extruder heater off,M140 S0 ;heated bed heater off (if you have it),M107 ;disable fans,G91 ;relative positioning,G1 E-10 F900 ;retract the filament a bit before lifting the nozzle to release some of the pressure,G1 Z+2 E-10 X-20 Y-20 F1500 ;move Z up a bit and retract filament even more,G1 X0 Y200 F1500 ;move bed to front,M84 ;steppers off,G90 ;absolute positioning,;{profile_string},M117 Hooooray!!!... ;Put printing message on LCD screen ; createX3G,0 ; celebration,0 ; celebrationSong,Star Wars ; createMB5G,0 ; postProcessing, ; defaultSpeed,1500 ; outlineUnderspeed,0.75 ; solidInfillUnderspeed,1 ; supportUnderspeed,1 ; rapidXYspeed,3000 ; rapidZspeed,1002 ; minBridgingArea,10 ; bridgingExtraInflation,0 ; bridgingExtrusionMultiplier,0.9 ; bridgingSpeedMultiplier,1 ; filamentDiameter,1.75 ; filamentPricePerKg,36 ; filamentDensity,1.25 ; useMinPrintHeight,0 ; minPrintHeight,0 ; useMaxPrintHeight,0 ; maxPrintHeight,0 ; useDiaphragm,0 ; diaphragmLayerInterval,20 ; robustSlicing,1 ; mergeAllIntoSolid,0 ; onlyRetractWhenCrossingOutline,0 ; retractBetweenLayers,1 ; useRetractionMinTravel,0 ; retractionMinTravel,3 ; retractWhileWiping,0 ; onlyWipeOutlines,1 ; avoidCrossingOutline,0 ; maxMovementDetourFactor,3 ; toolChangeRetractionDistance,0 ; toolChangeExtraRestartDistance,0 ; toolChangeRetractionSpeed,360 ; allowThinWallGapFill,1 ; thinWallAllowedOverlapPercentage,10 ; horizontalSizeCompensation,0 G90 M82 M106 S0 M104 S245 T0 M109 S245 T0 ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z5.0 F1500 ;move the platform down 15mm G1 Z0 ;move extruder to 0 G92 E0 ;zero the extruded length G1 F900 E20 ;extrude 10mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} M117 Leave me alone!... ;Put printing message on LCD screen G92 E0 G1 E-0.5000 F2400 G1 Z0.500 F1002 ; layer 1, Z = 0.5 T0 ; tool H0.500 W1.250 ; infill G1 X6.280 Y10 F3000 G1 E0.0000 F720 G92 E0 G1 X193.330 Y10 E48.6040 F750 G92 E0 G1 X193.330 Y15 F3000 G1 E0.0000 F720 G92 E0 G1 X6.280 Y15 E48.6040 F750 G92 E0 ; layer end ;End GCode M104 S0 ;extruder heater off M140 S0 ;heated bed heater off (if you have it) M107 ;disable fans G91 ;relative positioning G1 E-10 F900 ;retract the filament a bit before lifting the nozzle to release some of the pressure G1 Z+2 E-10 X-20 Y-20 F1500 ;move Z up a bit and retract filament even more G1 X0 Y200 F1500 ;move bed to front M84 ;steppers off G90 ;absolute positioning ;{profile_string} M117 Hooooray!!!... ;Put printing message on LCD screen ; Build Summary ; Build time: 0 hours 6 minutes ; Filament length: 1907.1 mm (1.91 m) ; Plastic volume: 4587.09 mm^3 (4.59 cc) ; Plastic weight: 5.73 g (0.01 lb) ; Material cost: 0.21
Re: Extruder hört nach Start auf zu Heizen, vielleicht G-Code Probleme? 13. June 2016 17:16 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Extruder hört nach Start auf zu Heizen, vielleicht G-Code Probleme? 14. June 2016 03:36 |
Re: Extruder hört nach Start auf zu Heizen, vielleicht G-Code Probleme? 14. June 2016 08:34 |
Re: Extruder hört nach Start auf zu Heizen, vielleicht G-Code Probleme? 14. June 2016 15:10 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 161 |
Re: Extruder hört nach Start auf zu Heizen, vielleicht G-Code Probleme? 14. June 2016 15:23 |
