Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 05:19 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 20 |
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 05:45 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 57 |
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 05:52 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 632 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 3.969 |
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 06:20 |
//If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif
du must den Z-min auf Z-max ändern, also deinen Endstop oben montieren und in der Firmware ändern.
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 06:24 |
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 06:33 |
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 06:54 |
#ifdef ENABLE_AUTO_BED_LEVELING ... #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif ... #endif // ENABLE_AUTO_BED_LEVELING
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 07:13 |
Re: Verständnis der Auto-Bed-Leveling Funktion 30. August 2016 07:48 |
