Re: Mendel90 Octoprint Auto Bed Leveling 05. December 2019 12:41 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 22 |
Re: Mendel90 Octoprint Auto Bed Leveling 11. December 2019 11:47 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 300 |
Re: Mendel90 Octoprint Auto Bed Leveling 12. December 2019 16:01 |
Re: Mendel90 Octoprint Auto Bed Leveling 12. December 2019 16:12 |
// @section homing // Specify here all the endstop connectors that are connected to any endstop or probe. // Almost all printers will be using one per axis. Probes will use one or more of the // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. //#define USE_XMIN_PLUG //#define USE_YMIN_PLUG //#define USE_ZMIN_PLUG #define USE_XMAX_PLUG #define USE_YMAX_PLUG #define USE_ZMAX_PLUG
* A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
* (e.g., an inductive probe or a nozzle-based probe-switch.)
//#define FIX_MOUNTED_PROBE
// @section homing //#define NO_MOTION_BEFORE_HOMING // Inhibit movement until all axes have been homed //#define UNKNOWN_Z_NO_RAISE // Don't raise Z (lower the bed) if Z is "unknown." For beds that fall when Z is powered off. //#define Z_HOMING_HEIGHT 10 // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ... // Be sure you have this distance over your Z_MAX_POS in case. // Direction of endstops when homing; 1=MAX, -1=MIN // :[-1,1] #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR 1
* Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
* Enable this option for a probe connected to the Z Min endstop pin.
//#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
Re: Mendel90 Octoprint Auto Bed Leveling 13. December 2019 12:21 |
Micro3D
@Hallo
Ich hatte es so schon versuch zu posten , hat er wohl nicht gespeichert
/** * A Fix-Mounted Probe either doesn't deploy or needs manual deployment. * (e.g., an inductive probe or a nozzle-based probe-switch.) */ //#define FIX_MOUNTED_PROBE
EDIT:
Es kann sein das du das auch noch deaktivieren musst
/** * Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN * * Enable this option for a probe connected to the Z Min endstop pin. */ //#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
EDIT:2
Kommando zurück ich glaube mit Marlin und denn Z_MAX Endstop wird es nichts , man könnte die Repetier Firmware versuchen . Das einfachste ist ein Z_MIN Endstop anzubauen.
MFG Stefan
Re: Mendel90 Octoprint Auto Bed Leveling 13. December 2019 13:27 |
