Noch ein Endstop Probleme, Anfänger verzweifelt 11. November 2013 16:50 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 101 |
Configuration.h
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 01:53 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 2.469 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 02:06 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.916 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 02:45 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 11:12 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 11:18 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 11:22 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 11:33 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 12:17 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 12:53 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 13:05 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 13:41 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 13:56 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 14:20 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 14:37 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 14:41 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 14:59 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.889 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 12. November 2013 16:48 |
Re: Noch ein Endstop Probleme, Anfänger verzweifelt 13. November 2013 04:52 |
