Slic3r erzeugt falschen Gcode 23. July 2012 04:42 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 27 |
Re: Slic3r erzeugt falschen Gcode 23. July 2012 04:57 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 3.742 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.004 |
Re: Slic3r erzeugt falschen Gcode 23. July 2012 05:07 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 30 |
Re: Slic3r erzeugt falschen Gcode 23. July 2012 05:10 |
Re: Slic3r erzeugt falschen Gcode 23. July 2012 05:21 |
Re: Slic3r erzeugt falschen Gcode 23. July 2012 05:24 |
Re: Slic3r erzeugt falschen Gcode 23. July 2012 05:42 |
This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 7874 [5206] [2656, 2657] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 36.75 This should never happen, there is a hole in the triangle mesh, each edge should have two faces. 7874 [5206] [2656, 2657] Something will still be printed, but there is no guarantee that it will be the correct shape. Once the gcode is saved, you should check over the layer with a z of: 37.05
Re: Slic3r erzeugt falschen Gcode 23. July 2012 06:28 |
