Z achse einstellen 04. October 2017 01:04 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 7 |
Re: Z achse einstellen 21. October 2017 16:35 |
Re: Z achse einstellen 22. October 2017 05:47 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 491 |
Re: Z achse einstellen 22. October 2017 05:50 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 581 |
Re: Z achse einstellen 22. October 2017 10:10 |
Re: Z achse einstellen 22. October 2017 10:37 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
#define INVERT_Z_DIR true // hier ändern ... // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 50 // sollte 0 sein #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 0 // hier den Abstand der Nozzle vom Bed nach dem Homen eintragenHerzl. Grüße
Re: Z achse einstellen 22. October 2017 10:53 |
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 200 #define X_MIN_POS 0 #define Y_MAX_POS 208 #define Y_MIN_POS 0 #define Z_MAX_POS 180 #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
#define INVERT_X_DIR false #define INVERT_Y_DIR true #define INVERT_Z_DIR true
Re: Z achse einstellen 22. October 2017 11:16 |
Re: Z achse einstellen 23. October 2017 09:44 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.112 |
Re: Z achse einstellen 01. November 2017 16:06 |
Re: Z achse einstellen 01. November 2017 16:52 |
Re: Z achse einstellen 01. November 2017 17:11 |
Re: Z achse einstellen 01. November 2017 17:36 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 300 |
// Manually set the home position. Leave these undefined for automatic settings. // For DELTA this is the top-center of the Cartesian print volume. //#define MANUAL_X_HOME_POS 0 //#define MANUAL_Y_HOME_POS 0 //#define MANUAL_Z_HOME_POS 0
Re: Z achse einstellen 01. November 2017 17:37 |
Re: Z achse einstellen 06. November 2017 16:30 |
