Endstopps in FW 03. January 2014 13:28 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 159 |
// ########################################################################################## // ## Endstop configuration ## // ########################################################################################## /* By default all endstops are pulled up to high. You need a pullup if you use a mechanical endstop connected with gnd. Set value to false for no pullup on this endstop. */ #define ENDSTOP_PULLUP_X_MIN false #define ENDSTOP_PULLUP_Y_MIN false #define ENDSTOP_PULLUP_Z_MIN false #define ENDSTOP_PULLUP_X_MAX true #define ENDSTOP_PULLUP_Y_MAX true #define ENDSTOP_PULLUP_Z_MAX false //set to true to invert the logic of the endstops #define ENDSTOP_X_MIN_INVERTING true #define ENDSTOP_Y_MIN_INVERTING true #define ENDSTOP_Z_MIN_INVERTING true #define ENDSTOP_X_MAX_INVERTING false #define ENDSTOP_Y_MAX_INVERTING false #define ENDSTOP_Z_MAX_INVERTING true // Set the values true where you have a hardware endstop. The Pin numbe ris taken from pins.h. #define MIN_HARDWARE_ENDSTOP_X true #define MIN_HARDWARE_ENDSTOP_Y true #define MIN_HARDWARE_ENDSTOP_Z false //true #define MAX_HARDWARE_ENDSTOP_X false #define MAX_HARDWARE_ENDSTOP_Y false #define MAX_HARDWARE_ENDSTOP_Z false //true //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here
#define MIN_HARDWARE_ENDSTOP_X true #define MIN_HARDWARE_ENDSTOP_Y true #define MIN_HARDWARE_ENDSTOP_Z false //true #define MAX_HARDWARE_ENDSTOP_X false #define MAX_HARDWARE_ENDSTOP_Y false #define MAX_HARDWARE_ENDSTOP_Z false //trueoder?
Re: Endstopps in FW 03. January 2014 14:08 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 1.916 |
Re: Endstopps in FW 03. January 2014 14:24 |
Re: Endstopps in FW 03. January 2014 14:53 |
mir ist ein Licht aufgegangen.
Re: Endstopps in FW 03. January 2014 18:54 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 531 |
Re: Endstopps in FW 04. January 2014 10:21 |
x_min: H y_min: L z_min: L
// ########################################################################################## // ## Endstop configuration ## // ########################################################################################## /* By default all endstops are pulled up to high. You need a pullup if you use a mechanical endstop connected with gnd. Set value to false for no pullup on this endstop. */ #define ENDSTOP_PULLUP_X_MIN false #define ENDSTOP_PULLUP_Y_MIN false #define ENDSTOP_PULLUP_Z_MIN false #define ENDSTOP_PULLUP_X_MAX false //true #define ENDSTOP_PULLUP_Y_MAX false //true #define ENDSTOP_PULLUP_Z_MAX false //set to true to invert the logic of the endstops #define ENDSTOP_X_MIN_INVERTING true #define ENDSTOP_Y_MIN_INVERTING true #define ENDSTOP_Z_MIN_INVERTING true #define ENDSTOP_X_MAX_INVERTING false #define ENDSTOP_Y_MAX_INVERTING false #define ENDSTOP_Z_MAX_INVERTING true // Set the values true where you have a hardware endstop. The Pin numbe ris taken from pins.h. #define MIN_HARDWARE_ENDSTOP_X true #define MIN_HARDWARE_ENDSTOP_Y true #define MIN_HARDWARE_ENDSTOP_Z true #define MAX_HARDWARE_ENDSTOP_X false #define MAX_HARDWARE_ENDSTOP_Y false #define MAX_HARDWARE_ENDSTOP_Z false //true //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here
Re: Endstopps in FW 04. January 2014 10:27 |
Re: Endstopps in FW 04. January 2014 11:12 |
x_min: L y_min: L z_min: L
// ########################################################################################## // ## Endstop configuration ## // ########################################################################################## /* By default all endstops are pulled up to high. You need a pullup if you use a mechanical endstop connected with gnd. Set value to false for no pullup on this endstop. */ #define ENDSTOP_PULLUP_X_MIN false #define ENDSTOP_PULLUP_Y_MIN false #define ENDSTOP_PULLUP_Z_MIN false #define ENDSTOP_PULLUP_X_MAX false #define ENDSTOP_PULLUP_Y_MAX false #define ENDSTOP_PULLUP_Z_MAX false //set to true to invert the logic of the endstops #define ENDSTOP_X_MIN_INVERTING false #define ENDSTOP_Y_MIN_INVERTING false #define ENDSTOP_Z_MIN_INVERTING false #define ENDSTOP_X_MAX_INVERTING false #define ENDSTOP_Y_MAX_INVERTING false #define ENDSTOP_Z_MAX_INVERTING false // Set the values true where you have a hardware endstop. The Pin numbe ris taken from pins.h. #define MIN_HARDWARE_ENDSTOP_X true #define MIN_HARDWARE_ENDSTOP_Y true #define MIN_HARDWARE_ENDSTOP_Z true #define MAX_HARDWARE_ENDSTOP_X false #define MAX_HARDWARE_ENDSTOP_Y false #define MAX_HARDWARE_ENDSTOP_Z false //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here
Re: Endstopps in FW 04. January 2014 11:22 |
Re: Endstopps in FW 04. January 2014 11:46 |
Re: Endstopps in FW 04. January 2014 12:00 |
Re: Endstopps in FW 04. January 2014 12:11 |
Re: Endstopps in FW 04. January 2014 16:57 |
Re: Endstopps in FW 04. January 2014 18:07 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 236 |
Re: Endstopps in FW 05. January 2014 08:09 |
sivar2311
Halte mal einen der Endstops gedrückt und mach erneut M119.
Der Gedrückte müsste dann auf H stehen.
Das mit allen Endstops machen um zu schauen ob sie überhaupt funktionieren.
Re: Endstopps in FW 05. January 2014 08:49 |
Re: Endstopps in FW 05. January 2014 09:11 |
Registrierungsdatum: 16 Jahre zuvor Beiträge: 339 |
// You can disable endstop checking for print moves. This is needed, if you get sometimes // false signals from your endstops. If your endstops don't give false signals, you // can set it on for safety. #define ALWAYS_CHECK_ENDSTOPS false
Re: Endstopps in FW 05. January 2014 09:52 |
Vollnormal
Versuch mal das folgende auf "true" zu ändern...
