Mendel90 Probleme Y Homing 28. May 2015 09:18 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 63 |
Re: Mendel90 Probleme Y Homing 28. May 2015 09:31 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Mendel90 Probleme Y Homing 28. May 2015 09:35 |
Re: Mendel90 Probleme Y Homing 28. May 2015 10:05 |
Re: Mendel90 Probleme Y Homing 28. May 2015 10:19 |
Re: Mendel90 Probleme Y Homing 28. May 2015 10:21 |
Re: Mendel90 Probleme Y Homing 28. May 2015 10:25 |
Re: Mendel90 Probleme Y Homing 28. May 2015 10:33 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 61 |
Re: Mendel90 Probleme Y Homing 28. May 2015 10:57 |
Re: Mendel90 Probleme Y Homing 28. May 2015 12:54 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 44 |
#define BED_CENTER_AT_0_0setzen.
#define MANUAL_X_HOME_POS (X_MIN_POS - 1) // MGS taken from Nopheads github was 0 #define MANUAL_Y_HOME_POS (Y_MIN_POS - 1) // MGS taken from Nopheads github was 0 #define MANUAL_Z_HOME_POS Z_HEIGHT_MM // MGS taken from neildarlows github was 0definierst, auch in den Zeilen darüber eigentlich //#define MANUAL_HOME_POSITIONS nicht auskommentiert sein sollte. Es scheint aber trotzdem zu funktionieren.
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. MGS const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. MGS const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop. MGSIch denke mal, dass ist auch was Wurstnase meinte, mit dem Hinweis genau zu schauen
Re: Mendel90 Probleme Y Homing 28. May 2015 17:56 |
Re: Mendel90 Probleme Y Homing 29. May 2015 00:27 |
Re: Mendel90 Probleme Y Homing 29. May 2015 03:13 |
Jupp, Die Marlin ist zwar nicht die aktuelle "Release" (1.0.2), aber keine "Alte". In der Entwicklung ist halt schon mehr Spielkram drin und bei den Geschwindigkeiten habe ich mir ein paar Konstanten definiert um nicht für jede Feinstabstimmung einen Taschenrechner bemühen zu müssen.Quote
Wurstnase
Mach dir keinen Kopp um die Marlin-Version. Die sollte laufen.
so lange wenn nichts gedrückt ist open da steht und gedrückt triggert, bist du auf dem richtigen weg.
Wenn der nicht auslöst, aber sollte, sind die Kabel verdrillt?
Re: Mendel90 Probleme Y Homing 29. May 2015 05:12 |
Re: Mendel90 Probleme Y Homing 29. May 2015 05:34 |
Re: Mendel90 Probleme Y Homing 29. May 2015 05:42 |
Re: Mendel90 Probleme Y Homing 29. May 2015 05:50 |
stevie72
Es ist so, dass die Endschalter zwar mit M119 getriggert werden aber bei einem weiteren Test bei dem ich die Endabschalter antippe nur der X Schalter wirklich auslöst.
Re: Mendel90 Probleme Y Homing 29. May 2015 06:00 |
Registrierungsdatum: 14 Jahre zuvor Beiträge: 3.742 |
Re: Mendel90 Probleme Y Homing 29. May 2015 06:14 |
Re: Mendel90 Probleme Y Homing 29. May 2015 07:12 |
Re: Mendel90 Probleme Y Homing 29. May 2015 07:16 |
#define PREVENT_DANGEROUS_EXTRUDE
Re: Mendel90 Probleme Y Homing 29. May 2015 07:57 |
Re: Mendel90 Probleme Y Homing 29. May 2015 08:00 |
stevie72
Ich habe warscheinlich damit richtig gelegen das mein Freund die OS etwas "modifiziert" hat .. deswegen klappte das hinten und vorne nicht.
Re: Mendel90 Probleme Y Homing 29. May 2015 19:25 |
Re: Mendel90 Probleme Y Homing 30. May 2015 10:43 |
Re: Mendel90 Probleme Y Homing 31. May 2015 05:58 |
#define PREVENT_DANGEROUS_EXTRUDEin der config auskommentiert. Wenn ich im kalten zustand auf extrude drücke läuft der Motor nicht ...
#define PREVENT_DANGEROUS_EXTRUDEverhindern das im kalten zustand extrudiert wird ? Demnach müsste doch der Motor drehen ... oder ?
Re: Mendel90 Probleme Y Homing 31. May 2015 08:01 |
#define TEMP_SENSOR_0 0ein und versuche es nochmals.
Re: Mendel90 Probleme Y Homing 31. May 2015 09:02 |
Ich bin mir nicht ganz sicher, ob ein Fehler bei den Temp-Sensoren das Extrudieren auch noch verhindert. Falls noch nicht gemacht, stelle bitte #define TEMP_SENSOR_0 0 ein und versuche es nochmals.
Ein Wort noch zu dem durchgebrannten A4988: Den maximalen Strom hast Du hoffentlich schon bei den Treiber eingestellt, oder?
#define TEMP_SENSOR_0 5setzen ..
Re: Mendel90 Probleme Y Homing 31. May 2015 10:01 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: Mendel90 Probleme Y Homing 31. May 2015 12:31 |
in den Kommentarzeilen davor steht aber:Quote
AlterBastler
Der Wert, der verändert werden muss, ist EXTRUDE_MINTEMP.
PREVENT_DANGEROUS_EXTRUDE begrenzt die extrudierte Länge, standardmäßig auf XMAX+YMAX.
Herzl. Grüße
//this prevents dangerous Extruder moves, i.e. if the temperature is under the limit //can be software-disabled for whatever purposes byWobei, wenn alles nicht hilft, AlterBastler natürlich recht hat. Für Testzwecke einfach die MINTEMP auf 0 und dann müsste der Extruder laufen oder es gibt noch ein anderes Problem.
