Firmware für Melzi gesucht - erledigt 20. August 2015 05:22 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 46 |
conficting return type specified for virtual size_tRFHardwareSerial:.write(uint8_t)
In file included from /Repetier.h:264, from Commands.cpp:22: /HAL.h:71:21: error: Arduino.h: No such file or directory In file included from /Repetier.h:264, from Commands.cpp:22: HAL.h:192: error: conflicting return type specified for 'virtual size_t RFHardwareSerial::write(uint8_t)' C:\Program Files (x86)\Arduino\hardware\Sanguino\cores\arduino/Print.h:40: error: overriding 'virtual void Print::write(uint8_t)' /HAL.h: In static member function 'static void HAL::digitalWrite(uint8_t, uint8_t)': HAL.h:449: error: '::digitalWrite' has not been declared /HAL.h: In static member function 'static uint8_t HAL::digitalRead(uint8_t)': HAL.h:453: error: '::digitalRead' has not been declared /HAL.h: In static member function 'static void HAL::pinMode(uint8_t, uint8_t)': HAL.h:457: error: '::pinMode' has not been declared /HAL.h: In static member function 'static void HAL::delayMicroseconds(unsigned int)': HAL.h:462: error: '::delayMicroseconds' has not been declared /HAL.h: In static member function 'static void HAL::delayMilliseconds(unsigned int)': HAL.h:466: error: '::delay' has not been declared /HAL.h: In static member function 'static void HAL::tone(uint8_t, int)': HAL.h:470: error: '::tone' has not been declared /HAL.h: In static member function 'static void HAL::noTone(uint8_t)': HAL.h:474: error: '::noTone' has not been declared /HAL.h: In static member function 'static void HAL::allowInterrupts()': HAL.h:512: error: 'sei' was not declared in this scope /HAL.h: In static member function 'static void HAL::forbidInterrupts()': HAL.h:516: error: 'cli' was not declared in this scope /HAL.h: In static member function 'static long unsigned int HAL::timeInMilliseconds()': HAL.h:520: error: 'millis' was not declared in this scope /HAL.h: In static member function 'static void HAL::spiInit(uint8_t)': HAL.h:573: error: 'HIGH' was not declared in this scope In file included from /Repetier.h:278, from Commands.cpp:22: /SdFat.h: At global scope: SdFat.h:1938: error: 'boolean' has not been declared In file included from /Repetier.h:356, from Commands.cpp:22: /Extruder.h: In static member function 'static void Extruder::step()': Extruder.h:107: error: 'HIGH' was not declared in this scope /Extruder.h: In static member function 'static void Extruder::unstep()': Extruder.h:166: error: 'LOW' was not declared in this scope In file included from /Repetier.h:385, from Commands.cpp:22: /Printer.h: In static member function 'static void Printer::endXYZSteps()': Printer.h:535: error: 'LOW' was not declared in this scope Printer.h:536: error: 'LOW' was not declared in this scope Printer.h:537: error: 'LOW' was not declared in this scope In file included from /Repetier.h:386, from Commands.cpp:22: /motion.h: In member function 'void PrintLine::startXStep()': motion.h:507: error: 'HIGH' was not declared in this scope /motion.h: In member function 'void PrintLine::startYStep()': motion.h:547: error: 'HIGH' was not declared in this scope /motion.h: In member function 'void PrintLine::startZStep()': motion.h:583: error: 'HIGH' was not declared in this scope Commands.cpp: In static member function 'static void Commands::setFanSpeed(int, bool)': Commands.cpp:213: error: 'constrain' was not declared in this scope Commands.cpp: In static member function 'static void Commands::executeGCode(GCode*)': Commands.cpp:526: error: 'sqrt' was not declared in this scope Commands.cpp:526: error: 'hypot' was not declared in this scope Commands.cpp:529: error: 'isnan' was not declared in this scope Commands.cpp:573: error: 'hypot' was not declared in this scope Commands.cpp:917: error: 'OUTPUT' was not declared in this scope Commands.cpp:917: error: 'pinMode' was not declared in this scope Commands.cpp:918: error: 'digitalWrite' was not declared in this scope Commands.cpp:919: error: 'analogWrite' was not declared in this scope Commands.cpp:1054: error: 'fabs' was not declared in this scope
Re: Firmware für Melzi gesucht 20. August 2015 12:07 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 7.616 |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Firmware für Melzi gesucht 21. August 2015 05:09 |
Re: Firmware für Melzi gesucht 21. August 2015 05:55 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Firmware für Melzi gesucht 21. August 2015 06:07 |
sketch_aug21a.ino:1:21: error: Arduino.h: No such file or directory sketch_aug21a:2: error: 'LOW' was not declared in this scope sketch_aug21a.ino: In function 'void setup()': sketch_aug21a:7: error: 'OUTPUT' was not declared in this scope sketch_aug21a:7: error: 'pinMode' was not declared in this scope sketch_aug21a.ino: In function 'void loop()': sketch_aug21a:12: error: 'millis' was not declared in this scope sketch_aug21a:16: error: 'LOW' was not declared in this scope sketch_aug21a:17: error: 'HIGH' was not declared in this scope sketch_aug21a:20: error: 'digitalWrite' was not declared in this scope
Re: Firmware für Melzi gesucht - erledigt 21. August 2015 10:39 |
