m107 mit MArlin und Sanguino1.2 geht nicht 02. April 2016 04:37 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 47 |
/**************************************************************************************** * Sanguinololu pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 62 #define MOTHERBOARD 6 #define SANGUINOLOLU_V_1_2 #endif #if MOTHERBOARD == 6 #define KNOWN_BOARD 1 #ifndef __AVR_ATmega644P__ #ifndef __AVR_ATmega1284P__ #error Oops! Make sure you have the appropriate 'Sanguino' selected from the 'Tools -> Boards' menu. #endif #endif #define X_STEP_PIN 15 #define X_DIR_PIN 21 #define X_MIN_PIN 18 #define X_MAX_PIN -2 #define Y_STEP_PIN 22 #define Y_DIR_PIN 23 #define Y_MIN_PIN 19 #define Y_MAX_PIN -1 #define Z_STEP_PIN 3 #define Z_DIR_PIN 2 #define Z_MIN_PIN 20 #define Z_MAX_PIN -1 #define E_STEP_PIN 1 #define E_DIR_PIN 0 /*#define PROBE_PIN 11*/ #define LED_PIN 27 #define FAN_PIN 4 #define PS_ON_PIN -1 #define KILL_PIN -1 #define HEATER_0_PIN 13 // (extruder) #ifdef SANGUINOLOLU_V_1_2 #define HEATER_1_PIN 12 // (bed) #define X_ENABLE_PIN 14 #define Y_ENABLE_PIN 14 #define Z_ENABLE_PIN 26 #define E_ENABLE_PIN 14 #else #define HEATER_1_PIN 14 // (bed) #define X_ENABLE_PIN -1 #define Y_ENABLE_PIN -1 #define Z_ENABLE_PIN -1 #define E_ENABLE_PIN -1 #endif #define TEMP_0_PIN 7 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! (pin 33 extruder) #define TEMP_1_PIN 6 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! (pin 34 bed) #define SDPOWER -1 #define SDSS 31 #ifndef KNOWN_BOARD #error Unknown MOTHERBOARD value in configuration.h #endif #endif #endifbei Marlin wird in der pins_Sanguino12.h auf die pins_Sanguino11.h verwiesen.
Re: m107 mit MArlin und Sanguino1.2 geht nicht 02. April 2016 05:07 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: m107 mit MArlin und Sanguino1.2 geht nicht 02. April 2016 05:18 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: m107 mit MArlin und Sanguino1.2 geht nicht 02. April 2016 06:46 |
/** * Sanguinololu board pin assignments */ #if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega1284P__) #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu. #endif #define X_STEP_PIN 15 #define X_DIR_PIN 21 #define X_STOP_PIN 18 #define Y_STEP_PIN 22 #define Y_DIR_PIN 23 #define Y_STOP_PIN 19 #define Z_STEP_PIN 3 #define Z_DIR_PIN 2 #define Z_STOP_PIN 20 #define E0_STEP_PIN 1 #define E0_DIR_PIN 0 #define LED_PIN 27 #define FAN_PIN 4 #if MB(AZTEEG_X1) || MB(STB_11) || MB(MELZI) #define FAN_PIN 4 // Works for Panelolu2 too #if MB(MELZI) #define LED_PIN 27 // On some broken versions of the Sanguino libraries the pin definitions are wrong, so LED_PIN needs to be 28. But you should upgrade your Sanguino libraries! See #368. #elif MB(STB_11) #define LCD_PIN_BL 17 // LCD backlight LED #endif #endifPin 27 hab ich ja oben schon auf LED_PIN gelegt das heist die abfrage "#if MB(AZTEEG_X1) || MB(STB_11) || MB(MELZI)" wird hier nicht durchlaufen.
Re: m107 mit MArlin und Sanguino1.2 geht nicht 02. April 2016 06:57 |
