BOARD_RAMPS_13_EFB und Z_PROBE_PIN 01. May 2016 04:40 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 2 |
// The following define selects which electronics board you have. // Please choose the name from boards.h that matches your setup #ifndef MOTHERBOARD // vorher #define MOTHERBOARD BOARD_RAMBO #define MOTHERBOARD BOARD_RAMPS_13_EFB #endif
Arduino: 1.6.8 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" sketch\Marlin_main.cpp:3296:36: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix] LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF"."); ^ In file included from sketch\Marlin.h:23:0, from sketch\Marlin_main.cpp:31: pins.h:2968: error: 'Z_PROBE_PIN' was not declared in this scope #define SENSITIVE_PINS {0, 1, X_STEP_PIN, X_DIR_PIN, X_ENABLE_PIN, X_MIN_PIN, X_MAX_PIN, Y_STEP_PIN, Y_DIR_PIN, Y_ENABLE_PIN, Y_MIN_PIN, Y_MAX_PIN, Z_STEP_PIN, Z_DIR_PIN, Z_ENABLE_PIN, Z_MIN_PIN, Z_PROBE_PIN, Z_MAX_PIN, PS_ON_PIN, \ ^ sketch\Marlin_main.cpp:406:30: note: in expansion of macro 'SENSITIVE_PINS' const int sensitive_pins[] = SENSITIVE_PINS; // Sensitive pin list for M42 ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: sketch\Marlin_main.cpp: In function 'void setup()': fastio.h:53: error: 'DIOZ_PROBE_PIN_DDR' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:653:3: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:653:3: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:45: error: 'DIOZ_PROBE_PIN_RPORT' was not declared in this scope #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ fastio.h:34: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:34: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:654:3: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOFAN2_PIN_DDR' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:658:5: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(CONTROLLERFAN_PIN); //Set pin used for driver cooling fan ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOFAN2_PIN_PIN' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:658:5: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(CONTROLLERFAN_PIN); //Set pin used for driver cooling fan ^ In file included from sketch\Configuration.h:841:0, from sketch\Marlin.h:22, from sketch\Marlin_main.cpp:31: Configuration_adv.h:64: error: 'FAN2_PIN' was not declared in this scope #define CONTROLLERFAN_PIN FAN2_PIN //Pin used for the fan to cool controller (-1 to disable) ^ sketch\Marlin_main.cpp:659:18: note: in expansion of macro 'CONTROLLERFAN_PIN' digitalWrite(CONTROLLERFAN_PIN, CONTROLLERFAN_SPEED_START); // kickstart for controller fan ^ sketch\Marlin_main.cpp: In function 'void clear_buffer()': sketch\Marlin_main.cpp:803:23: warning: converting to non-pointer type 'char' from NULL [-Wconversion-null] cmdbuffer[j] = NULL; ^ sketch\Marlin_main.cpp: In function 'void set_bed_level_equation_lsq(double*, bool)': sketch\Marlin_main.cpp:1184:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings] planeNormal.debug("planeNormal"); ^ sketch\Marlin_main.cpp: In function 'void run_z_probe()': Marlin_main.cpp:1278: error: 'Z_PROBE_PIN' was not declared in this scope if(zPosition == 0 && !digitalRead(Z_PROBE_PIN)^Z_PROBE_ENDSTOP_INVERTING) ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: sketch\Marlin_main.cpp: In function 'void process_commands()': fastio.h:51: error: 'DIOZ_PROBE_PIN_DDR' was not declared in this scope #define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= ~MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:74:24: note: in expansion of macro '_SET_INPUT' #define SET_INPUT(IO) _SET_INPUT(IO) ^ sketch\Marlin_main.cpp:2070:13: note: in expansion of macro 'SET_INPUT' SET_INPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:51: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= ~MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:74:24: note: in expansion of macro '_SET_INPUT' #define SET_INPUT(IO) _SET_INPUT(IO) ^ sketch\Marlin_main.cpp:2070:13: note: in expansion of macro 'SET_INPUT' SET_INPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:45: error: 'DIOZ_PROBE_PIN_RPORT' was not declared in this scope #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:34: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:34: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2071:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOZ_PROBE_PIN_DDR' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:2283:13: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:2283:13: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:45: error: 'DIOZ_PROBE_PIN_RPORT' was not declared in this scope #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:34: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:34: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2284:13: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:51: error: 'DIOZ_PROBE_PIN_DDR' was not declared in this scope #define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= ~MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:74:24: note: in expansion of macro '_SET_INPUT' #define SET_INPUT(IO) _SET_INPUT(IO) ^ sketch\Marlin_main.cpp:2666:9: note: in expansion of macro 'SET_INPUT' SET_INPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:51: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _SET_INPUT(IO) do {DIO ## IO ## _DDR &= ~MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:74:24: note: in expansion of macro '_SET_INPUT' #define SET_INPUT(IO) _SET_INPUT(IO) ^ sketch\Marlin_main.cpp:2666:9: note: in expansion of macro 'SET_INPUT' SET_INPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:45: error: 'DIOZ_PROBE_PIN_RPORT' was not declared in this scope #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:34: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:34: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2667:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, HIGH); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOZ_PROBE_PIN_DDR' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:2905:9: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:53: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _SET_OUTPUT(IO) do {DIO ## IO ## _DDR |= MASK(DIO ## IO ## _PIN); } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:76:25: note: in expansion of macro '_SET_OUTPUT' #define SET_OUTPUT(IO) _SET_OUTPUT(IO) ^ sketch\Marlin_main.cpp:2905:9: note: in expansion of macro 'SET_OUTPUT' SET_OUTPUT(Z_PROBE_PIN); ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:45: error: 'DIOZ_PROBE_PIN_RPORT' was not declared in this scope #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:34: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:34: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Marlin.h:21:0, from sketch\Marlin_main.cpp:31: fastio.h:39: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\ ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_WPORT' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ fastio.h:30: error: 'DIOZ_PROBE_PIN_PIN' was not declared in this scope #define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0) ^ sketch\fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0) ^ sketch\fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ sketch\Marlin_main.cpp:2906:9: note: in expansion of macro 'WRITE' WRITE(Z_PROBE_PIN, LOW); //Disable Z_PROBE when not in use ^ In file included from sketch\Configuration.h:841:0, from sketch\Marlin.h:22, from sketch\Marlin_main.cpp:31: sketch\Marlin_main.cpp: In function 'void controllerFan()': Configuration_adv.h:64: error: 'FAN2_PIN' was not declared in this scope #define CONTROLLERFAN_PIN FAN2_PIN //Pin used for the fan to cool controller (-1 to disable) ^ sketch\Marlin_main.cpp:4876:16: note: in expansion of macro 'CONTROLLERFAN_PIN' digitalWrite(CONTROLLERFAN_PIN, CONTROLLERFAN_SPEED_IDLE); ^ Configuration_adv.h:64: error: 'FAN2_PIN' was not declared in this scope #define CONTROLLERFAN_PIN FAN2_PIN //Pin used for the fan to cool controller (-1 to disable) ^ sketch\Marlin_main.cpp:4881:22: note: in expansion of macro 'CONTROLLERFAN_PIN' digitalWrite(CONTROLLERFAN_PIN, CONTROLLERFAN_SPEED_MIN); ^ Configuration_adv.h:64: error: 'FAN2_PIN' was not declared in this scope #define CONTROLLERFAN_PIN FAN2_PIN //Pin used for the fan to cool controller (-1 to disable) ^ sketch\Marlin_main.cpp:4890:22: note: in expansion of macro 'CONTROLLERFAN_PIN' digitalWrite(CONTROLLERFAN_PIN, CONTROLLERFAN_SPEED_FULL); ^ Configuration_adv.h:64: error: 'FAN2_PIN' was not declared in this scope #define CONTROLLERFAN_PIN FAN2_PIN //Pin used for the fan to cool controller (-1 to disable) ^ sketch\Marlin_main.cpp:4895:16: note: in expansion of macro 'CONTROLLERFAN_PIN' digitalWrite(CONTROLLERFAN_PIN, CONTROLLERFAN_SPEED_MAX); ^ exit status 1 'Z_PROBE_PIN' was not declared in this scope Dieser Bericht wäre detaillierter, wenn die Option "Ausführliche Ausgabe während der Kompilierung" in Datei -> Voreinstellungen aktiviert wäre.
// This determines the communication speed of the printer #define BAUDRATE 115200 ... #ifndef MOTHERBOARD #define MOTHERBOARD BOARD_RAMPS_13_EFB #endif ... #define TEMP_SENSOR_BED 11 .... //#define DEFAULT_AXIS_STEPS_PER_UNIT {100.5,100.5,1600,830} // default steps per unit for LulzBot TAZ #define DEFAULT_AXIS_STEPS_PER_UNIT {76,7590, 76,7590, 4000, 109,52} // für meinen Drucker // {76,7590, 76,7590, 4000, 109,52} //#define DEFAULT_MAX_FEEDRATE {800, 800, 3, 40} // (mm/sec) #define DEFAULT_MAX_FEEDRATE {300, 300, 5, 100} // (mm/sec).
Re: BOARD_RAMPS_13_EFB und Z_PROBE_PIN 03. May 2016 01:26 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 513 |
Re: BOARD_RAMPS_13_EFB und Z_PROBE_PIN 11. May 2016 14:36 |
RC6 - 23 Apr 2016 Completed support for CoreXY / CoreXZ in planner Changes to positioning behavior Various issues fixed. More details pending.Quelle
