Sparkcube Autoleveling Repetier FW 08. June 2016 16:46 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 5 |
Re: Sparkcube Autoleveling Repetier FW 09. June 2016 13:29 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
Re: Sparkcube Autoleveling Repetier FW 09. June 2016 15:17 |
Re: Sparkcube Autoleveling Repetier FW 09. June 2016 15:38 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Sparkcube Autoleveling Repetier FW 09. June 2016 15:47 |
Re: Sparkcube Autoleveling Repetier FW 13. June 2016 09:25 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 922 |
BED_CORRECTION_METHOD 0 Use a rotation matrix. This will make z axis go up/down while moving in x/y direction to compensate the tilt. For multiple extruders make sure the height match the tilt of the bed or one will scratch. BED_CORRECTION_METHOD 1 Motorized correction. This method needs a bed that is fixed on 3 points from which 2 have a motor to change the height. The positions are defined by BED_MOTOR_1_X, BED_MOTOR_1_Y, BED_MOTOR_2_X, BED_MOTOR_2_Y, BED_MOTOR_3_X, BED_MOTOR_3_Y Motor 2 and 3 are the one driven by motor driver 0 and 1. These can be extra motors like Felix Pro 1 uses them or a system with 3 z axis where motors can be controlled individually like the Sparkcube does.
Re: Sparkcube Autoleveling Repetier FW 13. June 2016 15:41 |
Re: Sparkcube Autoleveling Repetier FW 13. June 2016 18:15 |
Re: Sparkcube Autoleveling Repetier FW 16. June 2016 07:08 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 65 |
