Homing zu hoch 09. July 2017 12:33 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 19 |
Re: Homing zu hoch 09. July 2017 13:14 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1.610 |
Re: Homing zu hoch 09. July 2017 13:27 |
Re: Homing zu hoch 09. July 2017 13:46 |
Re: Homing zu hoch 09. July 2017 15:29 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 1.112 |
Re: Homing zu hoch 09. July 2017 17:35 |
Re: Homing zu hoch 10. July 2017 03:35 |
Re: Homing zu hoch 10. July 2017 05:01 |
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0 // Z offset: -below +above [the nozzle]
siehe hier:
Re: Homing zu hoch 10. July 2017 05:44 |
Re: Homing zu hoch 10. July 2017 07:30 |
Re: Homing zu hoch 10. July 2017 08:25 |
Re: Homing zu hoch 10. July 2017 08:42 |
Re: Homing zu hoch 10. July 2017 09:25 |
Re: Homing zu hoch 10. July 2017 10:38 |
//#define Z_HOMING_HEIGHT 4 // (in mm) Minimal z height[github.com]
Re: Homing zu hoch 10. July 2017 11:46 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
Re: Homing zu hoch 10. July 2017 11:57 |
Re: Homing zu hoch 10. July 2017 12:21 |
Re: Homing zu hoch 10. July 2017 12:28 |
Connecting... start Printer is now online. echo: Marlin 1.1.2 echo: Last Updated: 2017-05-30 12:00 | Author: (none, default config) Compiled: Jul 10 2017 echo: Free Memory: 3359 PlannerBufferBytes: 1232 echo: EEPROM version mismatch (EEPROM=? Marlin=V38) echo: Hardcoded Default Settings Loaded echo: G21 ; Units in mm echo: M149 C ; Units in Celsius echo: Filament settings: Disabled echo: M200 D3.00 echo: M200 D0 echo: Steps per unit: echo: M92 X200.00 Y200.00 Z3200.00 E291.00 echo:Maximum feedrates (units/s): echo: M203 X300.00 Y300.00 Z5.00 E25.00 echo:Maximum Acceleration (units/s2): echo: M201 X3000 Y3000 Z100 E10000 echo:Acceleration (units/s2): P R T echo: M204 P3000.00 R3000.00 T3000.00 echo:Advanced: S T B X Z E echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00 echo: Home offset: echo: M206 X0.00 Y0.00 Z0.00 echo:Auto Bed Leveling: echo: M420 S0 Z0.00 echo: Material heatup parameters: echo: M145 S0 H180 B70 F0 M145 S1 H240 B110 F0 echo: PID settings: echo: M301 P29.04 I3.25 D64.82 echo:Z-Probe Offset (mm): echo: M851 Z0.00 echo: SD init fail >>> g28 SENDING:G28 echo:busy: processing [...] echo:busy: processing >>> g29 SENDING:G29 echo:busy: processing [...] echo:busy: processing Bilinear Leveling Grid: 0 1 2 0 -0.042 -0.043 -0.353 1 +0.116 +0.524 +0.924 2 +0.063 +0.606 +1.128
Re: Homing zu hoch 10. July 2017 12:36 |
// For M851 give a range for adjusting the Z probe offset #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20
Re: Homing zu hoch 10. July 2017 12:57 |
Re: Homing zu hoch 10. July 2017 13:16 |
Re: Homing zu hoch 10. July 2017 13:19 |
Re: Homing zu hoch 10. July 2017 13:28 |
Re: Homing zu hoch 10. July 2017 14:10 |
Re: Homing zu hoch 10. July 2017 14:15 |
Re: Homing zu hoch 10. July 2017 14:38 |
Re: Homing zu hoch 10. July 2017 14:46 |
Re: Homing zu hoch 11. July 2017 06:19 |
Re: Homing zu hoch 11. July 2017 09:24 |
#define DEFAULT_MAX_FEEDRATE { 200, 200, 5, 100}
#define DEFAULT_MAX_ACCELERATION { 2000, 2000, 100, 10000 }
#define DEFAULT_ACCELERATION 1000
#define DEFAULT_RETRACT_ACCELERATION 1000
#define DEFAULT_TRAVEL_ACCELERATION 1000
#define DEFAULT_XJERK 15.0
#define DEFAULT_YJERK 15.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 5.0
Herzl. Grüße
Re: Homing zu hoch 11. July 2017 09:41 |
