export config file FROM printer - ???
03. November 2017 10:35
So i was messing around with my printer yesterday trying to get the bltouch servo to work (unsuccessfully) and had to resort back to the older marlin FW that was working. because i changed a few things since that file was last saved i had to calibrate the steps again (not ideal - but it was needed). BUT because it was late and i just wanted to get to bed i forgot to save the file with the current calibration factors.
with that said, does anyone know how to export the marlin files from the arduino board so that i can save it as a "working setup" instead of editing the config.h file all over again? thanks in advance.
also, i ran a few searches before deciding to write this request.
Re: export config file FROM printer - ???
03. November 2017 14:53
If your eeprom is enabled, you could use M503 to see the settings.
You could also readout the binary from flash, here is an example on how to do that: [www.hackster.io]
Herzl. Grüße
03. November 2017 15:51
Thanks Herzl, ill look into that!
03. November 2017 16:14
So glad someone loves me! grinning smiley
VDX
03. November 2017 18:00
grinning smiley
Viktor
