Brauche Hilfe... Geetech i3 pro W 17. March 2018 11:13 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 43 |
Re: Brauche Hilfe... Geetech i3 pro W 17. March 2018 16:14 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 03:39 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 448 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 07:19 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 08:15 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 08:18 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 300 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 08:22 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 08:58 |
// Enable pullup for all endstops to prevent a floating state #define ENDSTOPPULLUPS #if DISABLED(ENDSTOPPULLUPS) // Disable ENDSTOPPULLUPS to set pullups individually //#define ENDSTOPPULLUP_XMAX //#define ENDSTOPPULLUP_YMAX //#define ENDSTOPPULLUP_ZMAX //#define ENDSTOPPULLUP_XMIN //#define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN //#define ENDSTOPPULLUP_ZMIN_PROBE #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
// Direction of endstops when homing; 1=MAX, -1=MIN // :[-1,1] #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 // @section machine // The size of the print bed #define X_BED_SIZE 200 #define Y_BED_SIZE 200 // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS 200 #define Y_MAX_POS 200 #define Z_MAX_POS 200 /** * Software Endstops * * - Prevent moves outside the set machine bounds. * - Individual axes can be disabled, if desired. * - X and Y only apply to Cartesian robots. * - Use 'M211' to set software endstops on/off or report current state */ // Min software endstops constrain movement within minimum coordinate bounds #define MIN_SOFTWARE_ENDSTOPS #if ENABLED(MIN_SOFTWARE_ENDSTOPS) #define MIN_SOFTWARE_ENDSTOP_X #define MIN_SOFTWARE_ENDSTOP_Y #define MIN_SOFTWARE_ENDSTOP_Z #endif // Max software endstops constrain movement within maximum coordinate bounds #define MAX_SOFTWARE_ENDSTOPS #if ENABLED(MAX_SOFTWARE_ENDSTOPS) #define MAX_SOFTWARE_ENDSTOP_X #define MAX_SOFTWARE_ENDSTOP_Y #define MAX_SOFTWARE_ENDSTOP_Z #endif
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:08 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:18 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:22 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:31 |
Frei von den Endstops du meinst ich soll soweit von denen weg bis die nicht mehr auslösen?
Wenn ja das habe ich gemacht und da steht dann
x_min: open
y_min: open
z_min: open
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:34 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:52 |
x_min: TRIGGERED
y_min: TRIGGERED
z_min: TRIGGERED
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 09:58 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 10:13 |
Du meinst ich soll ermitteln, wie viel das von der Homing position bis zum anfang der glaskante ist also anfang druckbett?
// Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS -12 #define Y_MIN_POS 0 #define Z_MIN_POS 0
// @section extras // // EEPROM // // The microcontroller can store settings in the EEPROM, e.g. max velocity... // M500 - stores parameters in EEPROM // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. // #define EEPROM_SETTINGS // Enable for M500 and M501 commands //#define DISABLE_M503 // Saves ~2700 bytes of PROGMEM. Disable for release! #define EEPROM_CHITCHAT // Give feedback on EEPROM commands. Disable to save PROGMEM.
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 10:28 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 10:45 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 10:46 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 12:38 |
Ich
So gest du vor:
G28 X Y
G1 X0 Y0
jetzt mit der Düse manuel nach rechts fahren zum Druck bed rand.
Was steht da?
Habe ihn gerade mal mit cura anfangen lassen zu drucken damit ich seh ob er in die mitte fährt und JAAAAAAA er ist genau mittig!!!!!
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 13:14 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 13:34 |
Okay war es denn richtig das er mit den befehlen
G28 X Y
G1 X0 Y0
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 13:42 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 13:59 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 14:07 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 14:12 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 14:25 |
aber manchmal rattert er dann wenn er ankommt kommt so ein dröhnen des geräusch als wenn er ein wenig weiter fahren möchte es aber nicht geht.
// @section machine // The size of the print bed #define X_BED_SIZE 200 #define Y_BED_SIZE 190 Einfach mal zum testen // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS -12 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 200
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 14:58 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 15:06 |
Re: Brauche Hilfe... Geetech i3 pro W 18. March 2018 15:11 |
