Marlin 2.0 macht Probleme mit Treiber TMC2208 06. November 2019 13:03 |
Registrierungsdatum: 4 Jahre zuvor Beiträge: 21 |
18:57:05.787 : N16 M122*21 18:57:05.793 : X Z Z2 E 18:57:05.841 : Enabled false true false false 18:57:05.841 : Set current 1100 1100 1100 1300 18:57:05.872 : RMS current 1049 1049 1049 1270 18:57:05.926 : MAX current 1479 1479 1479 1791 18:57:05.926 : Run current 18/31 18/31 18/31 22/31 18:57:05.926 : Hold current 9/31 9/31 9/31 11/31 18:57:05.942 : CS actual 9/31 9/31 9/31 11/31 18:57:05.974 : PWM scale 11 11 0 13 18:57:05.990 : vsense 0=.325 0=.325 0=.325 0=.325 18:57:06.022 : stealthChop false false false false 18:57:06.038 : msteps 16 16 16 16 18:57:06.070 : tstep max max max max 18:57:06.070 : pwm 18:57:06.070 : threshold 18:57:06.070 : [mm/s] 18:57:06.124 : OT prewarn false false false false 18:57:06.124 : OT prewarn has 18:57:06.124 : been triggered false false false false 18:57:06.140 : off time 4 4 4 4 18:57:06.156 : blank time 24 16 24 24 18:57:06.156 : hysteresis 18:57:06.188 : -end 2 2 2 2 18:57:06.203 : -start 1 1 1 1 18:57:06.203 : Stallguard thrs 18:57:06.204 : DRVSTATUS X Z Z2 E 18:57:06.252 : stst * * * * 18:57:06.268 : olb * * * * 18:57:06.299 : ola * * * * 18:57:06.315 : s2gb 18:57:06.348 : s2ga 18:57:06.380 : otpw 18:57:06.412 : ot 18:57:06.443 : 157C 18:57:06.460 : 150C 18:57:06.492 : 143C 18:57:06.524 : 120C 18:57:06.524 : s2vsa 18:57:06.524 : s2vsb 18:57:06.539 : Driver registers: 18:57:06.539 : X 0x80:09:00:C0 18:57:06.540 : Z 0x80:09:00:C0 18:57:06.567 : Z2 0x80:09:00:C0 18:57:06.567 : E 0x80:0B:00:C0 18:57:06.567 : Testing X connection... OK 18:57:06.567 : Testing Z connection... OK 18:57:06.583 : Testing Z2 connection... OK 18:57:06.599 : Testing E connection... OKAber die Motoren laufen sehr unruhig und machen Lärm.
Re: Marlin 2.0 macht Probleme mit Treiber TMC2208 06. November 2019 15:59 |
//#define MONITOR_DRIVER_STATUS
Re: Marlin 2.0 macht Probleme mit Treiber TMC2208 06. November 2019 22:47 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 675 |
Re: Marlin 2.0 macht Probleme mit Treiber TMC2208 08. November 2019 17:13 |
Marlin 1.1.9 istt das letzte Release AUSSCHLIESSLICH für 8 bit boards. Marlin 2.0.x unterstützt AUCH 32 bit boards. Die Unterscheidung ob 8 oder 32 bit HW erfolgt beim Compilieren der Firmware hat also keinen Einfluss auf die Performance während des Betriebs. Diese Info ist zugegebenermassen etwas schwer zu finden. Im Ergebnis bedeutet das: es geht weiter mit 8 bit Unterstützung!!!!Deswegen war ich mir auch Sicher, das ich es benutzen kann.
Ja, dann werde ich einfach erst mal bei Marlin 1.1.9 bleiben.Quote
Hardwarekiller
Siehe auch hier da hab ich auch was geschrieben
Marlin2.0 Alpha NICHT verwenden für 8Bit
Re: Marlin 2.0 macht Probleme mit Treiber TMC2208 09. November 2019 02:13 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 1.610 |
