Creality V2.2 board for CR10S5 firmware issues. 26. December 2021 19:40 |
Registrierungsdatum: 2 Jahre zuvor Beiträge: 1 |
Windows PowerShell Copyright (C) Microsoft Corporation. All rights reserved. Try the new cross-platform PowerShell [aka.ms] PS C:\Marlin\Marlin-2.0.x> platformio run -e mega2560 Processing mega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino) ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: [docs.platformio.org] PLATFORM: Atmel AVR (3.4.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560) HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash DEBUG: Current (avr-stub) On-board (avr-stub, simavr) PACKAGES: - framework-arduino-avr 5.1.0 - toolchain-atmelavr 1.70300.191015 (7.3.0) Converting Marlin.ino LDF: Library Dependency Finder -> [bit.ly] LDF Modes: Finder ~ chain, Compatibility ~ soft Found 6 compatible libraries Scanning dependencies... Dependency Graph |-- 0.5.1 | |-- 1.0 | |-- 1.0 |-- 1.0 |-- 1.0 |-- 2.0 |-- 1.0 Building in release mode Compiling .pio\build\mega2560\src\src\inc\Warnings.cpp.o Compiling .pio\build\mega2560\src\src\lcd\dogm\marlinui_DOGM.cpp.o Compiling .pio\build\mega2560\src\src\lcd\dogm\u8g_dev_tft_upscale_from_128x64.cpp.o Compiling .pio\build\mega2560\src\src\lcd\dogm\u8g_dev_uc1701_mini12864_HAL.cpp.o Compiling .pio\build\mega2560\src\src\lcd\dogm\u8g_fontutf8.cpp.o Compiling .pio\build\mega2560\src\src\lcd\dogm\ultralcd_st7920_u8glib_rrd_AVR.cpp.o Compiling .pio\build\mega2560\src\src\lcd\extui\ui_api.cpp.o Compiling .pio\build\mega2560\src\src\lcd\fontutils.cpp.o Marlin\src\inc\Warnings.cpp:554:4: warning: #warning "Disabled CONFIGURATION_EMBEDDING because the target usually has less flash storage. Define FORCE_CONFIG_EMBED to override." [-Wcpp] #warning "Disabled CONFIGURATION_EMBEDDING because the target usually has less flash storage. Define FORCE_CONFIG_EMBED to override." ^~~~~~~ In file included from Marlin\src\lcd\dogm\marlinui_DOGM.cpp:46:0: #include "../../../_Bootscreen.h" ^~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated. *** [.pio\build\mega2560\src\src\lcd\dogm\marlinui_DOGM.cpp.o] Error 1 ================================================================================================== [FAILED] Took 5.78 seconds ================================================================================================== Environment Status Duration ------------- -------- ------------ mega2560 FAILED 00:00:05.781 ============================================================================================= 1 failed, 0 succeeded in 00:00:05.781 =============================================================================================PS C:\Marlin\Marlin-2.0.x> echo "done" >"C:\Users\Dad\AppData\Local\Temp\ipc" PS C:\Marlin\Marlin-2.0.x>
