Marlin 2.0.9.2 kompilieren Visual Studio Code 14. February 2022 12:42 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 94 |
Executing task in folder Marlin 2.0.9.2 Mix Extruder: C:\Users\User\.platformio\penv\Scripts\platformio.exe run <
Processing mega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino)
-------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
In file included from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfigPre.h:39:0,
from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfig.h:28,
from buildroot/share/PlatformIO/scripts/common-dependencies.h:29:
c:\users\user\documents\arduino\marlin 2.0.9.2 mix extruder\marlin\configuration.h:1:12: fatal error: U8glib-HAL.h: No such file or directory
* Looking for U8glib-HAL.h dependency? Check our library registry!
* CLI > platformio lib search "header:U8glib-HAL.h"
* Web > [registry.platformio.org]
#include
compilation terminated.
CalledProcessError: Command '"C:\Users\User\.platformio\packages\toolchain-atmelavr\bin\avr-g++.exe" -D__MARLIN_FIRMWARE__ -DNDEBUG -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.:
File "C:\Users\User\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 179:
env.SConscript(item, exports="env")
File "C:\Users\User\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py", line 597:
return _SConscript(self.fs, *files, **subst_kw)
File "C:\Users\User\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py", line 285:
exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals)
File "C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 320:
apply_features_config()
File "C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 139:
if not env.MarlinFeatureIsEnabled(feature):
File "C:\Users\User\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Util.py", line 742:
return self.method(*nargs, **kwargs)
File "C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 296:
load_marlin_features()
File "C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 284:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File "C:\Users\User\.platformio\python3\lib\subprocess.py", line 424:
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Users\User\.platformio\python3\lib\subprocess.py", line 528:
raise CalledProcessError(retcode, process.args,
=========================================== [FAILED] Took 0.89 seconds ===========================================
Environment Status Duration
mega2560 FAILED 00:00:00.895
====================================== 1 failed, 0 succeeded in 00:00:00.895 ======================================Der Terminalprozess "C:\Users\User\.platformio\penv\Scripts\platformio.exe 'run'" wurde mit folgendem Exitcode beendet: 1.
Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 15. February 2022 10:29 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 1.610 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 16. February 2022 05:13 |
../libraries/U8glib-HAL/src/U8glib-HAL@^0.5.1
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 16. February 2022 13:35 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 16. February 2022 19:25 |
Windows PowerShell Copyright (C) Microsoft Corporation. Alle Rechte vorbehalten. Lernen Sie das neue plattformübergreifende PowerShell kennen – [aka.ms] PS C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder> platformio run -e mega2560 Processing mega2560 (platform: atmelavr; board: megaatmega2560) --------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: [docs.platformio.org] PLATFORM: Atmel AVR (3.4.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560) HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash DEBUG: Current (avr-stub) On-board (avr-stub, simavr) PACKAGES: - toolchain-atmelavr 1.70300.191015 (7.3.0) LDF: Library Dependency Finder -> [bit.ly] LDF Modes: Finder ~ chain, Compatibility ~ soft Found 1 compatible libraries Scanning dependencies... Dependency Graph |-- 0.5.1 Building in release mode Compiling .pio\build\mega2560\src\src\HAL\AVR\HAL.o Compiling .pio\build\mega2560\src\src\HAL\AVR\HAL_SPI.o Compiling .pio\build\mega2560\src\src\HAL\AVR\MarlinSerial.o Compiling .pio\build\mega2560\src\src\HAL\AVR\Servo.o Compiling .pio\build\mega2560\src\src\HAL\AVR\eeprom.o Compiling .pio\build\mega2560\src\src\HAL\AVR\fast_pwm.o In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, Compiling .pio\build\mega2560\src\src\HAL\AVR\fastio.o from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\AVR\HAL_SPI.cpp:34: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "headerrint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\AVR\HAL.cpp:24: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > Compiling .pio\build\mega2560\src\src\HAL\AVR\u8g_com_HAL_AVR_sw_spi.o [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\AVR\MarlinSerial.cpp:39: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. Compiling .pio\build\mega2560\src\src\HAL\AVR\watchdog.o In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\AVR\Servo.cpp:55: Compiling .pio\build\mega2560\src\src\HAL\shared\Delay.o .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, Compiling .pio\build\mega2560\src\src\HAL\shared\HAL_MinSerial.o from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\AVR\eeprom.cpp:24: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > Compiling .pio\build\mega2560\src\src\HAL\shared\eeprom_api.o [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. Compiling .pio\build\mega2560\src\src\HAL\shared\esp_wifi.o Compiling .pio\build\mega2560\src\src\HAL\shared\servo.o In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\AVR\fast_pwm.cpp:24: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\AVR\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\AVR\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\AVR\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\AVR\watchdog.cpp:24: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\shared\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\shared\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\shared\Delay.h:24, from Marlin\src\HAL\shared\Delay.cpp:23: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\shared\../../core/../inc/../../Configuration.h:1:0, from Marlin\src\HAL\shared\../../core/../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\shared\../../core/../inc/MarlinConfig.h:28, from Marlin\src\HAL\shared\../../core/serial.h:24, from Marlin\src\HAL\shared\HAL_MinSerial.h:24, from Marlin\src\HAL\shared\HAL_MinSerial.cpp:22: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\shared\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\shared\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\shared\eeprom_api.cpp:23: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\shared\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\shared\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\shared\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\shared\esp_wifi.cpp:23: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\shared\../../inc/../../Configuration.h:1:0, from Marlin\src\HAL\shared\../../inc/MarlinConfigPre.h:39, from Marlin\src\HAL\shared\../../inc/MarlinConfig.h:28, from Marlin\src\HAL\shared\servo.cpp:53: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. Compiling .pio\build\mega2560\src\src\MarlinCore.o Compiling .pio\build\mega2560\src\src\core\serial.o *** [.pio\build\mega2560\src\src\HAL\AVR\HAL_SPI.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\AVR\HAL.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\AVR\MarlinSerial.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\AVR\Servo.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\AVR\eeprom.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\AVR\fast_pwm.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\AVR\watchdog.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\shared\Delay.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\shared\HAL_MinSerial.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\shared\eeprom_api.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\shared\esp_wifi.o] Error 1 *** [.pio\build\mega2560\src\src\HAL\shared\servo.o] Error 1 In file included from Marlin\src\inc/../../Configuration.h:1:0, from Marlin\src\inc/MarlinConfigPre.h:39, from Marlin\src\inc/MarlinConfig.h:28, from Marlin\src\MarlinCore.h:24, from Marlin\src\MarlinCore.cpp:31: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** #include ^~~~~~~~~ compilation terminated. *** [.pio\build\mega2560\src\src\MarlinCore.o] Error 1 In file included from Marlin\src\core\../inc/../../Configuration.h:1:0, from Marlin\src\core\../inc/MarlinConfigPre.h:39, from Marlin\src\core\../inc/MarlinConfig.h:28, from Marlin\src\core\serial.h:24, from Marlin\src\core\serial.cpp:23: .pio\libdeps\mega2560\U8glib-HAL\src/U8glib-HAL.h:43:12: fatal error: Print.h: No such file or directory *************************************************************** * Looking for Print.h dependency? Check our library registry! * * CLI > platformio lib search "header
rint.h" * Web > [rint.h" target="_blank" rel="nofollow">registry.platformio.org] * *************************************************************** ^~~~~~~~~ compilation terminated. *** [.pio\build\mega2560\src\src\core\serial.o] Error 1 ================================ [FAILED] Took 6.43 seconds ================================ Environment Status Duration ------------- -------- ------------ mega2560 FAILED 00:00:06.429 ========================== 1 failed, 0 succeeded in 00:00:06.429 ========================== PS C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder> echo "done" >"C:\Users\User\AppData\Local\Temp\ipc" PS C:\Users\User\Documents\Arduino\Marlin 2.0.9.2 Mix Extruder>
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 04:51 |
#ifdef U8G_HAL_LINKS
#include "U8glibPrint.h"
#define U8GLIB_PRINT_CLASS U8glibPrint
#else
#include < Print.h >
#define U8GLIB_PRINT_CLASS Print
#endif
[github.com]|
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 08:19 |
Windows PowerShell Copyright (C) Microsoft Corporation. Alle Rechte vorbehalten. Lernen Sie das neue plattformübergreifende PowerShell kennen – [aka.ms] PS C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC> platformio run -e mega2560 Processing mega2560 (board: megaatmega2560; platform: atmelavr@~3.4; framework: arduino) --------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option In file included from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfigPre.h:39:0, from buildroot/share/PlatformIO/scripts/../../../../Marlin/src/inc/MarlinConfig.h:28, from buildroot/share/PlatformIO/scripts/common-dependencies.h:29: c:\users\user\documents\arduino\marlin-2.0.9.2-vsc\marlin\configuration.h:1:10: fatal error: U8glib-HAL.h: No such file or directory ******************************************************************** * Looking for U8glib-HAL.h dependency? Check our library registry! * * CLI > platformio lib search "header:U8glib-HAL.h" * Web > [registry.platformio.org] * ******************************************************************** #include ^~~~~~~~~~~~~~ compilation terminated. CalledProcessError: Command '"C:\Users\User\.platformio\packages\toolchain-atmelavr\bin\avr-g++.exe" -DU8G_HAL_LINKS -D__MARLIN_FIRMWARE__ -DNDEBUG -DU8G_HAL_LINKS -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.: File "C:\Users\User\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 179: env.SConscript(item, exports="env") File "C:\Users\User\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py", line 597: return _SConscript(self.fs, *files, **subst_kw) File "C:\Users\User\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py", line 285: exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals) File "C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 247: apply_features_config() File "C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 133: if not env.MarlinFeatureIsEnabled(feature): File "C:\Users\User\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Util.py", line 742: return self.method(*nargs, **kwargs) File "C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 216: load_marlin_features() File "C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 204: define_list = run_preprocessor(env) File "C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC\buildroot\share\PlatformIO\scripts\preprocessor.py", line 42: define_list = subprocess.check_output(cmd, shell=True).splitlines() return run(*popenargs, stdout=PIPE, timeout=timeout, check=True, File "C:\Users\User\.platformio\python3\lib\subprocess.py", line 528: raise CalledProcessError(retcode, process.args, ================================ [FAILED] Took 1.01 seconds ================================ Environment Status Duration ------------- -------- ------------ mega2560 FAILED 00:00:01.009 ========================== 1 failed, 0 succeeded in 00:00:01.009 ========================== PS C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC> echo "done" >"C:\Users\User\AppData\Local\Temp\ipc" PS C:\Users\User\Documents\Arduino\Marlin-2.0.9.2-VSC>
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 09:36 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 12:30 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 13:34 |
// CONTROLLER TYPE: Graphical 128x64 (DOGM)
// IMPORTANT: The U8glib library is required for Graphical Display! --> Das heißt nicht, daß Du den Programmcode ändern sollst, sondern nur, daß die Bibliothek vorhanden sein muß
// [github.com]
// NOTE: If the LCD is unresponsive you may need to reverse the plugs.
Herzl. Grüße
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 15:29 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 17. February 2022 16:06 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 18. February 2022 02:33 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 18. February 2022 04:13 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 18. February 2022 15:45 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 26 |
Re: Marlin 2.0.9.2 kompilieren Visual Studio Code 18. February 2022 15:56 |
