mehr Lüfter am/über das Mega2560/RAMPS steuern 25. June 2014 15:58 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 3.385 |
Re: mehr Lüfter am/über das Mega2560/RAMPS steuern 25. June 2014 17:27 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.689 |
Re: mehr Lüfter am/über das Mega2560/RAMPS steuern 26. June 2014 03:57 |
Re: mehr Lüfter am/über das Mega2560/RAMPS steuern 27. June 2014 10:48 |
//This is for controlling a fan to cool down the stepper drivers //it will turn on when any driver is enabled //and turn off after the set amount of seconds from last driver being disabled again #define CONTROLLERFAN_PIN -1 //Pin used for the fan to cool controller (-1 to disable) #define CONTROLLERFAN_SECS 60 //How many seconds, after all motors were disabled, the fan should run #define CONTROLLERFAN_SPEED 255 // == full speed // When first starting the main fan, run it at full speed for the // given number of milliseconds. This gets the fan spinning reliably // before setting a PWM value. (Does not work with software PWM for fan on Sanguinololu) //#define FAN_KICKSTART_TIME 100 // Extruder cooling fans // Configure fan pin outputs to automatically turn on/off when the associated // extruder temperature is above/below EXTRUDER_AUTO_FAN_TEMPERATURE. // Multiple extruders can be assigned to the same pin in which case // the fan will turn on when any selected extruder is above the threshold. #define EXTRUDER_0_AUTO_FAN_PIN -1 #define EXTRUDER_1_AUTO_FAN_PIN -1 #define EXTRUDER_2_AUTO_FAN_PIN -1 #define EXTRUDER_AUTO_FAN_TEMPERATURE 50 #define EXTRUDER_AUTO_FAN_SPEED 255 // == full speed
Re: mehr Lüfter am/über das Mega2560/RAMPS steuern 27. June 2014 12:59 |
#define FAN_BOARD_PIN 4
