Hotend wird nicht heisser wie 150C 30. November 2017 18:14 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 35 |
#define EXT0_HEAT_MANAGER 1 /** Wait x seconds, after reaching target temperature. Only used for M109. Overridden if EEPROM activated. */ #define EXT0_WATCHPERIOD 1 /** \brief The maximum value, I-gain can contribute to the output. A good value is slightly higher then the output needed for your temperature. Values for starts: 130 => PLA for temperatures from 170-180 deg C 180 => ABS for temperatures around 240 deg C The precise values may differ for different nozzle/resistor combination. Overridden if EEPROM activated. */ #define EXT0_PID_INTEGRAL_DRIVE_MAX 205 /** \brief lower value for integral part The I state should converge to the exact heater output needed for the target temperature. To prevent a long deviation from the target zone, this value limits the lower value. A good start is 30 lower then the optimal value. You need to leave room for cooling. Overridden if EEPROM activated. */ #define EXT0_PID_INTEGRAL_DRIVE_MIN 60 /** P-gain. Overridden if EEPROM activated. */ #define EXT0_PID_PGAIN_OR_DEAD_TIME 24 /** I-gain. Overridden if EEPROM activated. */ #define EXT0_PID_I 0.88 /** Dgain. Overridden if EEPROM activated.*/ #define EXT0_PID_D 80 // maximum time the heater is can be switched on. Max = 255. Overridden if EEPROM activated. #define EXT0_PID_MAX 255
Re: Hotend wird nicht heisser wie 150C 01. December 2017 02:58 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 888 |
