Hilfe: Stepper TMC2209 mit Nema17 Schrittmotor "zuckt" nur 21. January 2024 04:59 |
Registrierungsdatum: 1 Jahr zuvor Beiträge: 1 |
#define X_DRIVER_TYPE TMC2209 #define Y_DRIVER_TYPE TMC2209 #define Z_DRIVER_TYPE TMC2209 #define E0_DRIVER_TYPE TMC2209
/** * Default Axis Steps Per Unit (linear=steps/mm, rotational=steps/°) * Override with M92 * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] */ #define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 500 } /** * Default Max Feed Rate (linear=mm/s, rotational=°/s) * Override with M203 * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] */ #define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 } //#define LIMITED_MAX_FR_EDITING // Limit edit via M203 or LCD to DEFAULT_MAX_FEEDRATE * 2 #if ENABLED(LIMITED_MAX_FR_EDITING) #define MAX_FEEDRATE_EDIT_VALUES { 600, 600, 10, 50 } // ...or, set your own edit limits #endif /** * Default Max Acceleration (speed change with time) (linear=mm/(s^2), rotational=°/(s^2)) * (Maximum start speed for accelerated moves) * Override with M201 * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] */ #define DEFAULT_MAX_ACCELERATION { 1000, 1000, 100, 10000 } //#define LIMITED_MAX_ACCEL_EDITING // Limit edit via M201 or LCD to DEFAULT_MAX_ACCELERATION * 2 #if ENABLED(LIMITED_MAX_ACCEL_EDITING) #define MAX_ACCEL_EDIT_VALUES { 6000, 6000, 200, 20000 } // ...or, set your own edit limits #endif /** * Default Acceleration (speed change with time) (linear=mm/(s^2), rotational=°/(s^2)) * Override with M204 * * M204 P Acceleration * M204 R Retract Acceleration * M204 T Travel Acceleration */ #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration for travel (non printing) moves
#define MICROSTEP_MODES { 16, 16, 16, 16, 16, 16 } // [1,2,4,8,16]
#if HAS_TRINAMIC_CONFIG || HAS_TMC26X #define HOLD_MULTIPLIER 0.5 // Scales down the holding current from run current /** * Interpolate microsteps to 256 * Override for each driver with _INTERPOLATE settings below */ #define INTERPOLATE true #if AXIS_IS_TMC_CONFIG(X) #define X_CURRENT 750 // (mA) RMS current. Multiply by 1.414 for peak current. #define X_CURRENT_HOME X_CURRENT // (mA) RMS current for sensorless homing #define X_MICROSTEPS 64 // 0..256 #define X_RSENSE 0.11 // Multiplied x1000 for TMC26X #define X_CHAIN_POS -1 // -1..0: Not chained. 1: MCU MOSI connected. 2: Next in chain, ... //#define X_INTERPOLATE true // Enable to override 'INTERPOLATE' for the X axis //#define X_HOLD_MULTIPLIER 0.5 // Enable to override 'HOLD_MULTIPLIER' for the X axis #endif #if AXIS_IS_TMC_CONFIG(Y) #define Y_CURRENT 800 #define Y_CURRENT_HOME Y_CURRENT #define Y_MICROSTEPS 16 #define Y_RSENSE 0.11 #define Y_CHAIN_POS -1 //#define Y_INTERPOLATE true //#define Y_HOLD_MULTIPLIER 0.5 #endif #if AXIS_IS_TMC_CONFIG(Z) #define Z_CURRENT 800 #define Z_CURRENT_HOME Z_CURRENT #define Z_MICROSTEPS 16 #define Z_RSENSE 0.11 #define Z_CHAIN_POS -1 //#define Z_INTERPOLATE true //#define Z_HOLD_MULTIPLIER 0.5 #endif
Re: Hilfe: Stepper TMC2209 mit Nema17 Schrittmotor "zuckt" nur 21. January 2024 15:59 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 634 |
