Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 22. July 2014 07:34 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 27 |
; generated by Slic3r 1.1.5 on 2014-07-22 at 13:17:36 ; perimeters extrusion width = 0.35mm ; infill extrusion width = 0.35mm ; solid infill extrusion width = 0.35mm ; top infill extrusion width = 0.35mm G21 ; set units to millimeters M107 M104 S215 ; set temperature G28 ; home all axis G1 Z5 F5000 ; lift nozzle M109 S215 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0 . . . G92 E0 M107 G28 ; home all axis ; G28 X0 ; home X axis G1 E-2 F30 ; retract 2mm M104 S0 ; turn off temperature M84 ; disable motors ; filament used = 1599.7mm (3.8cm3) ; avoid_crossing_perimeters = 0 ; bed_size = 200,200 ; bed_temperature = 0 ; bridge_acceleration = 0 ; bridge_fan_speed = 100 ; bridge_flow_ratio = 0.8 ; brim_width = 0 ; complete_objects = 0 ; cooling = 1 ; default_acceleration = 0 ; disable_fan_first_layers = 1 ; duplicate_distance = 6 ; end_gcode = \nG28 ; home all axis\n; G28 X0 ; home X axis\nG1 E-2 F30 ; retract 2mm\nM104 S0 ; turn off temperature\nM84 ; disable motors ; external_perimeters_first = 0 ; extruder_clearance_height = 20 ; extruder_clearance_radius = 20 ; extruder_offset = 0x0 ; extrusion_axis = E ; extrusion_multiplier = 0.92 ; fan_always_on = 1 ; fan_below_layer_time = 60 ; filament_diameter = 1.75 ; first_layer_acceleration = 0 ; first_layer_bed_temperature = 0 ; first_layer_extrusion_width = 150% ; first_layer_speed = 30% ; first_layer_temperature = 215 ; g0 = 0 ; gcode_arcs = 0 ; gcode_comments = 0 ; gcode_flavor = reprap ; infill_acceleration = 0 ; infill_first = 0 ; layer_gcode = ; max_fan_speed = 100 ; min_fan_speed = 55 ; min_print_speed = 10 ; min_skirt_length = 0 ; notes = ; nozzle_diameter = 0.35 ; only_retract_when_crossing_perimeters = 1 ; ooze_prevention = 0 ; output_filename_format = [input_filename_base].gcode ; perimeter_acceleration = 0 ; post_process = ; print_center = 0,0 ; resolution = 0 ; retract_before_travel = 2 ; retract_layer_change = 1 ; retract_length = 1 ; retract_length_toolchange = 10 ; retract_lift = 0 ; retract_restart_extra = 0 ; retract_restart_extra_toolchange = 0 ; retract_speed = 30 ; skirt_distance = 10 ; skirt_height = 1 ; skirts = 3 ; slowdown_below_layer_time = 30 ; spiral_vase = 0 ; standby_temperature_delta = -5 ; start_gcode = G28 ; home all axis\nG1 Z5 F5000 ; lift nozzle\n ; temperature = 215 ; threads = 2 ; toolchange_gcode = ; travel_speed = 130 ; use_firmware_retraction = 0 ; use_relative_e_distances = 0 ; vibration_limit = 0 ; wipe = 0 ; z_offset = 0 ; dont_support_bridges = 1 ; extrusion_width = 0.35 ; first_layer_height = 150% ; infill_only_where_needed = 0 ; interface_shells = 0 ; layer_height = 0.2 ; raft_layers = 0 ; seam_position = aligned ; support_material = 0 ; support_material_angle = 0 ; support_material_enforce_layers = 0 ; support_material_extruder = 1 ; support_material_extrusion_width = 0 ; support_material_interface_extruder = 1 ; support_material_interface_layers = 3 ; support_material_interface_spacing = 0 ; support_material_interface_speed = 100% ; support_material_pattern = pillars ; support_material_spacing = 2.5 ; support_material_speed = 20 ; support_material_threshold = 0 ; bottom_solid_layers = 3 ; bridge_speed = 20 ; external_perimeter_speed = 70% ; extra_perimeters = 1 ; fill_angle = 45 ; fill_density = 40% ; fill_pattern = rectilinear ; gap_fill_speed = 20 ; infill_every_layers = 1 ; infill_extruder = 1 ; infill_extrusion_width = 0 ; infill_speed = 20 ; overhangs = 1 ; perimeter_extruder = 1 ; perimeter_extrusion_width = 0 ; perimeter_speed = 20 ; perimeters = 3 ; small_perimeter_speed = 20 ; solid_fill_pattern = rectilinear ; solid_infill_below_area = 30 ; solid_infill_every_layers = 0 ; solid_infill_extrusion_width = 0 ; solid_infill_speed = 20 ; thin_walls = 1 ; top_infill_extrusion_width = 0 ; top_solid_infill_speed = 20 ; top_solid_layers = 3
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 22. July 2014 15:28 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 140 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 02:07 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 03:06 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 03:17 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 08:56 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 14:29 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 15:31 |
Re: Infill reicht nicht bis zum Rand [slic3r | Repetier | Delta] 23. July 2014 15:46 |
