I'm having a hard time printing ABS for some reason. I'm using a makergear extruder with a .35mm nozzle and 3mm filament. The ABS strips out on the gear rather than feed through, regardless of how slow I run it through.
I have the heat set at 220C. Increasing it to 240 does not help, nor does reducing the temperature.
Black and white filament both have the same problem, so I don't think it's a roll of bad filament.
PLA will extrude with no problem. Any ideas?
