Sounds like your extrusion rate may be too high. In Pronterface, you can experiment with changes to your extrusion rate using either
M92 Ennn or
M221 Snn.
Since you may not know your starting steps per unit (usually in Configuration.h), you may want to try using M221 first, as it lets you input a percentage. Start the print, then type M221 S95, then M221 S90 (5% reductions in extrusion) on smaller parts until you get the dims you want. Then you can go into configuration.h and set the proper extrusion steps by taking you final % and multiplying it what exists in firmware. Or, I suppose you can always add it to your "Start Print" gcode.
Normally you can run these commands live as you're printing, but I'm not sure changing the extrusion rate will be noticeable for you unless you are printing solid layers. See the
calibration guide for setting your extrusion steps for better info. In short, you want to print a near solid layer (0.95 infill) and adjust the extrusion rate until you can just barely see gaps between the infill lines.
Edited 2 time(s). Last edit at 08/19/2013 06:49PM by Filip.
