Low Layer Height Issues March 09, 2014 09:16AM |
Re: Low Layer Height Issues March 09, 2014 01:27PM |
ayouden
I tried to print the cute octo today with a 0.05mm layer height.
As you can see, the majority of the print is perfect.
However, the waving leg and the top is very bad!
does anyone have any tips on how to fix this?
I am using 1.75mm white ABS
Thanks
Re: Low Layer Height Issues March 09, 2014 01:47PM |
Re: Low Layer Height Issues March 09, 2014 02:23PM |
ayouden
okay, what about it's little leg poking up, that went really bad.
Re: Low Layer Height Issues March 09, 2014 02:34PM |
Re: Low Layer Height Issues March 09, 2014 03:00PM |
Re: Low Layer Height Issues March 09, 2014 03:06PM |
ayouden
I currently use 3 perimeters, upping that to 6-10, would that solve it if i kept the infill the same?
Re: Low Layer Height Issues March 09, 2014 03:50PM |
Re: Low Layer Height Issues March 09, 2014 04:50PM |
ayouden
Looks like increasing the infill is the way to go, is there a good infill to use other than the default rectilinear?
Thanks
Re: Low Layer Height Issues March 09, 2014 06:29PM |
Re: Low Layer Height Issues March 09, 2014 07:42PM |
gmh39
Just a heads up, you cant do 100% infill with honeycomb.
Re: Low Layer Height Issues March 10, 2014 05:14AM |
Re: Low Layer Height Issues March 10, 2014 08:45AM |
